P4U1 Posted February 18, 2005 Share Posted February 18, 2005 I have an aero top supra which makes loads of noise from the roof when you are driving, i think the car has particularly hard suspension which doesnt help, but i think the rubbers etc need replacing as the roof panel isnt coping with the movement you get, at least not quietly Can anyone help? Is it possible to have an aero top supra which when driving makes no noise? Ta Paul Quote Link to comment Share on other sites More sharing options...
JustGav Posted February 18, 2005 Share Posted February 18, 2005 Check that the bolts are tight that hold the off... mine rattles a bit if I leave one slightly loose. GAv Quote Link to comment Share on other sites More sharing options...
P4U1 Posted February 18, 2005 Author Share Posted February 18, 2005 Ok will do, im also getting some rattles from the boot area? Quote Link to comment Share on other sites More sharing options...
hadyn Posted February 18, 2005 Share Posted February 18, 2005 im also getting some rattles from the boot area? mine does this too, its knackered boot rubbers - as a short term fix, put a load of vaseline(no joke) on the rubbers on the boot and boot lid, that will dampen the rattle noise a bit Quote Link to comment Share on other sites More sharing options...
P4U1 Posted February 18, 2005 Author Share Posted February 18, 2005 ahh k thanks, where can i get new rubbers from? Quote Link to comment Share on other sites More sharing options...
hadyn Posted February 18, 2005 Share Posted February 18, 2005 where can i get new rubbers from? Toyota, do a search for the part number Quote Link to comment Share on other sites More sharing options...
Supragal Posted February 18, 2005 Share Posted February 18, 2005 Have a look in the technical section mate, there are lots of thrads about creaks etc and some interesting ones about boot rubbers and also similar sounds that weren't the boot rubbers Quote Link to comment Share on other sites More sharing options...
P4U1 Posted February 18, 2005 Author Share Posted February 18, 2005 ta supragirl Quote Link to comment Share on other sites More sharing options...
C4 SUP Posted March 27, 2005 Share Posted March 27, 2005 I have an aero top supra which makes loads of noise from the roof when you are driving, i think the car has particularly hard suspension which doesnt help, but i think the rubbers etc need replacing as the roof panel isnt coping with the movement you get, at least not quietly Can anyone help? Is it possible to have an aero top supra which when driving makes no noise? Ta Paul Just seen this post. I have an aerotop that doesn`t rattle and the bolts also do not need to be tightened every few miles. My last aerotop did rattle and did need tightening every now and again. So I guess its just luck of the draw!! Ian Quote Link to comment Share on other sites More sharing options...
lpher Posted March 27, 2005 Share Posted March 27, 2005 My experience is that if you take care and park the car on even ground when you fasten your roof, it can go many months before you have to tighten the screws. But..if you put on the roof when parked just a little bit off of even ground...youll have to tighten the screws very often Quote Link to comment Share on other sites More sharing options...
