Supra ST Myster Posted June 13, 2008 Share Posted June 13, 2008 In May i had the a/c refilled as had the rad changed over, and was working great for a couple of weeks, ive not used it since end of May and went to use it yday and its not working, did the diagnostic check and its the pressure switch it reckons, so does that mean the gas has leaked again, surly in a space of a month or so the machine would of seen a leak when it checks the sytem if its bad enough to loose all the gas in such little time? Or could it be something else? Basically when you press the A/C button the light comes on but nothing else kicks in. Bit like before i had it regassed Quote Link to comment Share on other sites More sharing options...
MRX Posted June 13, 2008 Share Posted June 13, 2008 I have the same problem... considering just removing the AC completely. Quote Link to comment Share on other sites More sharing options...
Angarak Posted June 13, 2008 Share Posted June 13, 2008 Get down to an A/C specialist, they can leak test it with a luminous die. Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 13, 2008 Share Posted June 13, 2008 i had the same problem and it turned out to be the schrieder valve in the low high pressure side ( or was it the High ..... never mind ) , Anyway the machine wouldn't detect this leak as when the machine is coupled upto the A/C system these valves would be depressed inwards thus breaking the little 'O' ring seal .... May not be your problem but its just a thought and worth a check Can't you see any of the bright green dye anywhere ? Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 13, 2008 Author Share Posted June 13, 2008 not had a real look yet but they did use green dye when they filled it up so i must be able to see it somewhere in that case. If not will take it down somewhere Quote Link to comment Share on other sites More sharing options...
MisterSheen Posted June 13, 2008 Share Posted June 13, 2008 Emin, I'd recommend these peeps , used them about 3 weeks ago http://www.stsmotorsport.co.uk/aircon.asp Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 14, 2008 Author Share Posted June 14, 2008 cheers mate, will give them a shout Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted June 14, 2008 Share Posted June 14, 2008 Ibrar services the aircon systems so may be worth having a word with him. He did mine at JAE last year. Top chap and soo much cheaper than everywhere else. See this thread for some feedback http://www.mkivsupra.net/vbb/showthread.php?t=121479&highlight=aircon+service Quote Link to comment Share on other sites More sharing options...
