UK TT really slow
Lionel
Hi Guys,
I really need your help. I have UK spec TT, but it feels so slow. 2nd turbo doesn't kick in at all. One more thing that I'm concern of is , that my boost gauge shows -6 bar on idle. And then i push the full throttle it goes to 0,5 bar. :search:
Can someone tell me what is wrong with it?
Thanks.
Hi Guys,
Thanks.
probably a boost leak, or sticking activators mate, do a search and there will be endless advice and pics;)
The negative pressure is normal as the engine is sucking the air in when it's at idle, when the turbo's are in action this will change to a positive pressure as the air is forced into the engine by the turbo's.
It'll be -0.6 mate. Not -6bar! lol
Sounds ok apart from the no second turbo. Like other said a split hose or other issue. Do a search on the forum though mate. I had a problem with a sticking EGBV actuator and after alot of reading/searching, managed to sort it all out.
Hi Guys,
Thanks.
vacuum -6 is normal on idle as said earlier, check all your pipes for leaks, vsv maybe
Edited by supraGZaerotop (see edit history)
Changed most of the hoses, found a screw in one, that was completely blocking one of the hoses. Then I've tried, I've got my 2nd turbo back!!!! It kicked in only for one time , but that's a start. Will go and check other things as well.
yep as discussed if vaccum pressure was 6bar...I would imagine all your intercooler hoses if rubber would crimp up, I would say boost leak as well, mosy reduced boost levels are due to some sort of leak
I think a boost gauge measures atmospheric pressure, so wouldn't -1 bar be a total vacuum?
