hks fcd trouble
mellonman
Check voltage from Map sensor, make sure the FCD is getting power and that its getting ground (recheck wiring) , also, make sure the FCD isnt a Type K (will have more than 4 wires)
As your getting 0v out, i would make sure your getting a Voltage in, could be a bad FCD or just a bad solder connection (dont use crimp connections)
