spiderpigcity Posted June 11, 2008 Share Posted June 11, 2008 do i need the pipe that leads from the canister to the metal pipe that runs along the inlet manifold and then branches off in to a tee , one going to thee throttle position sensor area and the other to the vaccum line nearthe oil fillter. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted June 11, 2008 Share Posted June 11, 2008 If I'm understanding you correctly, I believe you are referring to the pipe that is to the left of the below picture. The one with the bolt in it. Also you can see the pipe where the hose attaches to the pipe that if I remember correctly went to the tank under the intake manifold: Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted June 11, 2008 Author Share Posted June 11, 2008 If I'm understanding you correctly, I believe you are referring to the pipe that is to the left of the below picture. The one with the bolt in it. Also you can see the pipe where the hose attaches to the pipe that if I remember correctly went to the tank under the intake manifold: http://i201.photobucket.com/albums/aa39/Casey-Kev/Weekend25-11-07011.jpg yes thats the one , do i need it or can i blank it off at the canister end and just join the two pipes together where the tee was? Quote Link to comment Share on other sites More sharing options...
Kev.O Posted June 11, 2008 Share Posted June 11, 2008 I'm no expert but I don't think you need the tank/can the hose attaches to, so no need to connect it through. You will need to blank the pipe from the T/B though. I removed my charcoal canister, so I'm not sure what to do with the pipe leaving the canister, sorry Matt. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted June 11, 2008 Share Posted June 11, 2008 Go onto Clubna-t.com and search for 'charcoal cannister removal'. There is a full walkthrough on there about removing it and what to do with the left over pipes. I would get the link for you but i am at work and cannot access clubna-t website. Quote Link to comment Share on other sites More sharing options...
