marc_p Posted June 11, 2008 Share Posted June 11, 2008 I have a problem! after doing the following, the car is still overfuelling and I don't know what's causing it? Changed O2 sensors Reset ECU (did this by disconnecting battery for an hour) Changed spark plugs Oil change Standard air box and filter on I don't know what else it could be but the car does pop quite a lot and I get about 200 miles to £65 of fuel driving sensibly (that's not booting it at all) If I boot it the fuel economy is rediculous, I'd probably get about 100 miles from a full tank. So, any Ideas, it's just at the moment i'm spending a fair few hundred a month on petrol. Cheers Marc Quote Link to comment Share on other sites More sharing options...
marc_p Posted June 12, 2008 Author Share Posted June 12, 2008 Quote Link to comment Share on other sites More sharing options...
supra_si Posted June 12, 2008 Share Posted June 12, 2008 have you replaced the fuel pump? that is quite high economy as i get about 100 miles to 25 quid on my twin Quote Link to comment Share on other sites More sharing options...
marc_p Posted June 12, 2008 Author Share Posted June 12, 2008 Okay, fuel pump added to list, cheers Quote Link to comment Share on other sites More sharing options...
Pig Posted June 12, 2008 Share Posted June 12, 2008 Could it be the fuel pressure regulator (or what ever it is they have as stock) Or more likely i would say an injector might be stuck open (maybe take them out and get them cleaned) Please be aware my knowledge is rubbish Quote Link to comment Share on other sites More sharing options...
supra_si Posted June 12, 2008 Share Posted June 12, 2008 yeh good spot, fpr could be dodgy, not much to change either Quote Link to comment Share on other sites More sharing options...
marc_p Posted June 12, 2008 Author Share Posted June 12, 2008 Could it be the fuel pressure regulator (or what ever it is they have as stock) Or more likely i would say an injector might be stuck open (maybe take them out and get them cleaned) Please be aware my knowledge is rubbish It's all appreciated mate. Well injectors have moved to top of the list as that's the cheapest and easiest to check. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted June 12, 2008 Share Posted June 12, 2008 It's all appreciated mate. Well injectors have moved to top of the list as that's the cheapest and easiest to check. Are you sure?? The stock fpr is the easiest to check. I had an overfuelling problem for months which is now sorted so if you need a hand, drop me a PM. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 12, 2008 Share Posted June 12, 2008 Removing and checking injectors is definitely not easy at all! Quote Link to comment Share on other sites More sharing options...
supra_si Posted June 12, 2008 Share Posted June 12, 2008 and injectors actually cost quite a bit Quote Link to comment Share on other sites More sharing options...
