Digital cameras, "refresh" time??
Chris Wilson
Do the more expensive SLR type digital still cameras refresh a lot faster these days? My Sony thing (not an SLR by any means) is a PITA for nature shots, by the time it's ready to take the next photo the subject has moved, gone or something has intervened. Do any work as fast as a motor drive on a normal film SLR? Ta!
I love the function to take 4 or 5 photos one after the other on my canon (400d) Can take a good 5 photos in a second, pretty useful. I found it went even faster using a descent memory card too.
It's rated as 3 frames per second with large image size, but it should be slightly faster with speedier memory. I think 5 is pushing it a bit though.
An SLR is definately the way to go though, no lag between pressing the shutter and it taking the photo, unlike most compacts.
as I think someone else has said, make sure whatever one you buy has a bloody quick card in it, 150x speed cards are common and good :)
It's not essential, SLR's are quick enough anyway, unless doing back to back testing with rapid fire I doubt you'd notice.
But when a Sandisk "Extreme III" 4GB compact flash card is only around £14 then it's worth getting.
The new canon 450d can manage 3.5 frames a second continuous and there is no noticale shutter lag. Shots are instant. Have a look at some of the photos I took at biggin hill this weekend. Capturing jets on a low flyby just wouldnt be possible with a compact or bridge camera.
http://picasaweb.google.com/GrandDaddyRob/
Some nice pics there Grand Daddy ;)
Some quite noticeable vignetting though, what lens did you use?
Sigma 150-500 HSM OS DG, Odd that you say theres vignetting as its a full frame lens on an APS-C sized sensor.
Yeah not usually an issue with full frame lenses, but this one for example http://picasaweb.google.com/GrandDaddyRob/BigginHillAirFare2008/photo#5209547206343647442 it's quite noticeable. Were they taken right at the full 500mm end? You could always try zoomed out a little from max and can always crop the photos a little. I suspect it's just more noticeable because of the plain bright blue background.
Not that it detracts from your photo's at all and a lot of people add vignetting effects in post-processing as it helps to frame the subject anyway :)
The focal length varies. If you click on more information to the right of the photo you can see the iso, shutter speed, f stop and focal length etc
None of those pics have had any post processing, just resized and dropped the quality for the web.
