Duffman Posted June 9, 2008 Share Posted June 9, 2008 Not sure if it aint wokring or if i perhaps jus aint doing it right (neva had it b4) How exactly do i use it...& check if faulty? Link to comment Share on other sites More sharing options...
juanchan Posted June 9, 2008 Share Posted June 9, 2008 Push the end of the cruise control stick in. "Cruise" appears below the odometer to say it's on. Then click the cruise control lever down at your desired speed and it will set itslef to your current speed. You can increase/decrease speed by clicking the lever up and down. Accelerate, it'll come back to the cruise speed when you let off the throttle. Brake and it'll deactivate itself. Once deavtivated, click the lever up once and it'll return itself to the cruise speed very gently, so good for high(er) mpg. Link to comment Share on other sites More sharing options...
KKMMK2N Posted June 9, 2008 Share Posted June 9, 2008 Check for a blown brake light bulb as this will deactivate the cruise control so the cruise light doesn't come on when you press the button. Link to comment Share on other sites More sharing options...
turbonut Posted June 9, 2008 Share Posted June 9, 2008 aha!! wondered how it worked Cheers Lx Link to comment Share on other sites More sharing options...
juanchan Posted June 9, 2008 Share Posted June 9, 2008 I've heard that J-spec cruise can't be set over about 70mph btw. Not that any of you would want to go that fast, naturally, but thought I'd let you know Link to comment Share on other sites More sharing options...
bmx1lew Posted June 9, 2008 Share Posted June 9, 2008 yeah if your doing 80mph and try to set it, it will slow the car down to 70 then set. One thing I have always wounderd about was, With cruise controle, if its set to 50 it will try stay there if going up or down a hill, When going down hill you can feel the car slowing itself down but I wounderd if the brake lights come on? Lew. Link to comment Share on other sites More sharing options...
Konrad Posted June 9, 2008 Share Posted June 9, 2008 yeah if your doing 80mph and try to set it, it will slow the car down to 70 then set. One thing I have always wounderd about was, With cruise controle, if its set to 50 it will try stay there if going up or down a hill, When going down hill you can feel the car slowing itself down but I wounderd if the brake lights come on? Lew. I don;t think cruise control is using brakes at all man. It just operate with releasing and pressing down acceleration pedal. Link to comment Share on other sites More sharing options...
supra_si Posted June 9, 2008 Share Posted June 9, 2008 yeh mines tops out at 72mph which is just enough for motorways lol Link to comment Share on other sites More sharing options...
Duffman Posted June 10, 2008 Author Share Posted June 10, 2008 Check for a blown brake light bulb as this will deactivate the cruise control so the cruise light doesn't come on when you press the button. Checked brake lights...working fine. Also my horn doesn't work at all....do you think the horn and cruise control not working could be linked in anyway? Link to comment Share on other sites More sharing options...
juanchan Posted June 10, 2008 Share Posted June 10, 2008 yeah if your doing 80mph and try to set it, it will slow the car down to 70 then set. One thing I have always wounderd about was, With cruise controle, if its set to 50 it will try stay there if going up or down a hill, When going down hill you can feel the car slowing itself down but I wounderd if the brake lights come on? Lew. I think Konrad's right.... I don;t think cruise control is using brakes at all man. It just operate with releasing and pressing down acceleration pedal. I was in a 40 limit with cruise on recently, going down a steep hill and the speed slowly increased. I had to brake to stop myself from going through a camera at 50. Link to comment Share on other sites More sharing options...
NeoMagic Posted June 10, 2008 Share Posted June 10, 2008 My cruise control doesn’t work until I’m doing over 50 mph ish. Link to comment Share on other sites More sharing options...
