5 mannual Gear box in a TT
SpeedyAndy
hey all,
i was just wondering as my mate has had a TT conversion from N/A but had to keep the 5 mannual gear box, i no if he wanted to increase BHP then he will have to upgrade the gear box to the 6 mannual speed gear box!
but i was just wondering if you re-build the gear and set the radio different etc ( like you do on a engine to increase power)would the gear box be able to handle more power from the engine, has he has been told only to BHP up to 420 / 430 BPH has the gear box wouldn't be able to handle the power ??
has any one had this done before or done it them selfs ?
Many Thanks
Speedy Andy
Not sure what you mean there. You can't really set the ratios differently (presuming you meant ratio rather than radio) on these gearboxes, or any other common production car gearbox that I'm aware of.
Also don't know what you mean about setting ratios/radio/gears differently in engines to gain power.
hey all,
Many Thanks
Speedy Andy
I would just get a 6 speed box Andy...
1. Its purposed built for the job...
2. You will have a limited top speed with the 5 speed box because with the lesser gear, you will just be hitting your rev limiter and doing no favours for your engine...
IF you can get an OS GIKEN gearset for the W58 (though i think only the R154 was available) then yes, you can rebuild it to take the power, but your looking at over 3K for the 5 speed set, cheaper going the 6 speed route unless your serious about using the a 5 speed close ratio setup and big power.
yes sorry i do mean ratio ( mistype error )
Many Thanks for your comments, i think it would be easyer just saving up for the 6 mannual gear box, i only asked as i didn't know and someone told me about it as they have re-built a gear box but not for a supra for a evo!
Thanks again for advise!
Andy
Save up for the 6spd while waiting on the 5spd to go pop. I don't really think the 5spd boxes are worth much/anything so just tell him to enjoy the car until he can afford a 6spd.
Can the final drive in the 5spd be changed?
My BPU car kicks out just over 500ft/lb of torque.
are you sure? Guys on here with singles are getting around 500.
Stock is around 325lb-ft
Edit, just did a search for Wez's car. His torque curve is one of the best for a street single. He is pushing 520lb-ft and 560bhp and you reckon you are pushing the same torque BPU? Must be a first.
Edited by Scott (see edit history)
hey all,
Many Thanks
Speedy Andy
For god sakes man proof read what you write.
so its the torque he needs to be careful off with blowing the 5pd gear box? as it not really the BHP
and is it right to only to take it up to 420 - 450 BHP before it best to have the 6sp gear box ?
BHP doesn't matter, its the torque. The reason for the general rule of 450 is because, normally, you will be hitting around 400-450lb-ft of torque which will blow the box.
If you had 10000bhp and only 200lb-ft of torque you would be fine :D
