Homer Posted June 6, 2008 Share Posted June 6, 2008 Is it a straight swap to fit an LSD diff from an auto TT into an NA? I.e. are the prop and driveshafts the same? I'm led to beleive that the NA diffs are the same open type whether they are auto or 5spd manual, can anyone verify that? I know the 6spd is a completely different matter, but am not sure about the auto TT diffs... TIA Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 6, 2008 Share Posted June 6, 2008 AFAIK yes, they'll interchange. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 6, 2008 Share Posted June 6, 2008 AFAIK yes, they'll interchange. The EPC would suggest they are too. Quote Link to comment Share on other sites More sharing options...
Homer Posted June 6, 2008 Author Share Posted June 6, 2008 Thanks very much gents That saves one major headache! Quote Link to comment Share on other sites More sharing options...
Guest kponx Posted June 9, 2008 Share Posted June 9, 2008 so what's that supposed to mean?? i mean what's the major diffs?? Quote Link to comment Share on other sites More sharing options...
steve spedd Posted December 13, 2009 Share Posted December 13, 2009 bumping this... Im interested to know if i can fit an Auto TT diff on my Manual NA? is this possible without changing any other part? thanks Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2009 Share Posted December 13, 2009 bumping this... Im interested to know if i can fit an Auto TT diff on my Manual NA? is this possible without changing any other part? thanks I have a feeling the donuts are different fitting. Quote Link to comment Share on other sites More sharing options...
steve spedd Posted December 13, 2009 Share Posted December 13, 2009 Ah, ok. Do you know how strong the stock NA diff is? Just wondering if its something i need to look at changing if more power is going through it.... Quote Link to comment Share on other sites More sharing options...
Homer Posted December 13, 2009 Author Share Posted December 13, 2009 The diff is a direct drop in, not sure about the donut bit but they will at least bolt up. If anything the auto TT might be stronger, but this is the first I've heard of them being different. You might need the 2nd bush hanger mount and bolt if the NA subframe doesn't have it already. The auto diff is stonger, but will have a big impact on gear ratio's, the gearing will be quite a bit longer with one fitted to an NA. See my gear calculator to get an idea. Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2009 Share Posted December 13, 2009 (edited) The donuts are different im sure, where the propshaft meets the diff the 3 17mm bolts are spaced differently between the na and tt diff i think, im pretty sure you would have to change the prop although i could be wrong, it has been known:d Edited December 13, 2009 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
steve spedd Posted December 13, 2009 Share Posted December 13, 2009 cheers for the help guys.... Quote Link to comment Share on other sites More sharing options...
keron Posted December 14, 2009 Share Posted December 14, 2009 The donuts are different im sure, where the propshaft meets the diff the 3 17mm bolts are spaced differently between the na and tt diff i think, im pretty sure you would have to change the prop although i could be wrong, it has been known:d spot on...spaced out differently...so not a direct swap. bolts in as such except for the prop-diff connection. Quote Link to comment Share on other sites More sharing options...
