Tyres : Confused!
boxst
Hello
I should know better, but I don't! Although I thought my tyres were fine, I have noticed that they have worn almost completely away on the inner rim (all 4 of them) so I need some new tyres.
At the moment I have 255/40/17 on the back and 235/45/17 on the front.
What make should I replace them with? The cheapest vs quality seems to be Dunlop 9000 (Z).
Any suggestions appreciated.
Steve
Who would I get to adjust the tracking? Is that something the Toyota garage would have to do?
I was looking to spend £500- £600. The Dunlops are £520.
Steve
Ahh your budget is pleanty then. A lot of garages do tracking. You will find that the garage you take your car to get the tyres fitted will most likely do it. Basic tracking is easy enough for any garage, if you want a full alignment and geometry setup its better to go to a specialist. There are a few of them dotted around the UK, if you do a search on here you might get lucky and find one local :)
Now.. tyres...
You actually have a good choice for that budget. I would probably go for either Goodyear Eagle F1's, Toyo proxies or Bridgestone Potenza.
The most expensive of the above are the Bridgestone's at around £130 each for the front and rears.
Check out www.mytyres.co.uk All prices include postage. Most of the time i go with them.
