Preping car for RR Day
Dann
Ok so am going to do my first RR day.
with all other event were a car gets raced or used hard there is alot of prep required for the cars to get the best out of them. So was wondering what is required to prep a car for a rolling road, I would like to see the best out of my car.
Vmax fuel.
Tighten accelerator cable
New oil ? or shall I change it after RR day
Tyre pressures ? better to be harder ?
clean up air filter
Diff oil should I change will it make a difference
Gear oil should I change will it make a difference
Anything else I should do.
I know many people just go and put the car on the rollers but I want to make sure I get the best out my supra. Any advice you can give I will be most grateful.
Many thanks
Dann
I find it almost impossible to watch mine on rollers
I would have thought your list was ok, as long as the car has been fully serviced recently I would not worry, where are you getting it done, a lot of problems come from poor RR method rather than the cars having big issues
