badge01 Posted June 4, 2008 Share Posted June 4, 2008 Alright guys and gals, just after a bit of advise really, i took my supe out at lunch 2day and it drove fine, but when i was going back to work it started handling really bad. The back end just feels really loose when going round corners, hard to explain really its a bit like a boat.... Any ideas?? Link to comment Share on other sites More sharing options...
snake Posted June 4, 2008 Share Posted June 4, 2008 check the wheel nuts first ,incase someone tried to borrow the wheels. Link to comment Share on other sites More sharing options...
badge01 Posted June 4, 2008 Author Share Posted June 4, 2008 yeah checked those all ok cheers, any other ideas? Link to comment Share on other sites More sharing options...
rob wild Posted June 4, 2008 Share Posted June 4, 2008 The things i'd check would be:- 1) Tyre pressures 2) Rear shocks (for leakage etc) 3) Subframe bolts 4) GEO alignment (obviously via a garage) 5) Rear Bushes Also i had a sticking rear calliper a few years back which affected the handling. Hope you get it sorted Link to comment Share on other sites More sharing options...
badge01 Posted June 4, 2008 Author Share Posted June 4, 2008 cheers mate, will check after work 2moro.. Link to comment Share on other sites More sharing options...
badge01 Posted June 5, 2008 Author Share Posted June 5, 2008 ok checked my car and i have found that the big bush on the rear sub - frame is starting to split, would this cause the problem? Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 5, 2008 Share Posted June 5, 2008 What bush is that? Unlikely is my guess. you don't mean the differential to subframe bushes, do you? They are meant to be void bushes. Link to comment Share on other sites More sharing options...
