R-TT Posted June 3, 2008 Share Posted June 3, 2008 iv got a steering wheel vibration but its only ever 5 seconds or so then its fine then its not again. iv had 3 sets of wheels on so its not the balancing, iv had the camber an syuff checked and aparantly theres no major play in any of the bushes that can be seen from underneath any1 had similar probs? cheers Quote Link to comment Share on other sites More sharing options...
Guest supra virgin 1 Posted June 3, 2008 Share Posted June 3, 2008 I would automatically say that its tracking - usually most noticable at higher speed ie 70 - 80. After that i would say that if you have after market alloys on do they fit properly ? you may need spacers ? Quote Link to comment Share on other sites More sharing options...
drnas78 Posted June 3, 2008 Share Posted June 3, 2008 balancing mor ethen tracking espacially at 60+ mph you need to get tyres re balanced Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 4, 2008 Share Posted June 4, 2008 Road surface and tyre tread design is also a major factor in steering vibration, i get vibration at certain speeds but only on certain roads. Quote Link to comment Share on other sites More sharing options...
broomie Posted June 4, 2008 Share Posted June 4, 2008 what size wheels you running? Quote Link to comment Share on other sites More sharing options...
R-TT Posted June 6, 2008 Author Share Posted June 6, 2008 18s with eagle f1s 275 front 235 rear had camber tracking done an its still the same, had 3 sets of whhels on, 2 freshly balanced and ones that came on it. might start changing bushes, was wondering which were most common to go? Quote Link to comment Share on other sites More sharing options...
creative Posted June 6, 2008 Share Posted June 6, 2008 spigot rings? I've recently noticed I havent got any on mine and I get vibration at 60+ mph. Done exactly the same as you and had it all checked out and this is really the only thing thats left Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted June 7, 2008 Share Posted June 7, 2008 18s with eagle f1s 275 front 235 rear had camber tracking done an its still the same, had 3 sets of whhels on, 2 freshly balanced and ones that came on it. might start changing bushes, was wondering which were most common to go? 275 front's?? 235 rear's?? Do you mean 235 front's and 275 rear's?? Quote Link to comment Share on other sites More sharing options...
SpeedyAndy Posted June 7, 2008 Share Posted June 7, 2008 does this happen when you first start your car and start to drive ? Quote Link to comment Share on other sites More sharing options...
danny_silva Posted June 7, 2008 Share Posted June 7, 2008 my 318 ci did that... it was only when i applied the brakes and for 4 for 5 secs!! it was the front discs!!!! Quote Link to comment Share on other sites More sharing options...
Max Headroom Posted June 7, 2008 Share Posted June 7, 2008 275 front's?? 235 rear's?? Do you mean 235 front's and 275 rear's?? Yeah that!! Quote Link to comment Share on other sites More sharing options...
SpeedyAndy Posted June 7, 2008 Share Posted June 7, 2008 my 318 ci did that... it was only when i applied the brakes and for 4 for 5 secs!! it was the front discs!!!! very true, have you checkd this ? does this happen when you first start your car and start to drive ? or when apply the brakes ? Quote Link to comment Share on other sites More sharing options...
R-TT Posted June 7, 2008 Author Share Posted June 7, 2008 sorry, 275 rears. happens all the time slightly at lowere speeds and more at higher discs look in real good nic happens weather braking accelerating ang cruising, seems to be after it hits slight bump in the road tho Quote Link to comment Share on other sites More sharing options...
dr_blackman Posted June 7, 2008 Share Posted June 7, 2008 I get this vibration at higher speeds too.... i've kinda given up trying to find out why now.... had wheels balanced by loads of people all fine, geo set up, I've been wondering if its the tires..... Quote Link to comment Share on other sites More sharing options...
GazB Posted June 7, 2008 Share Posted June 7, 2008 A buckled wheel may be to blame try a different tyre centre for balancing and tell them youv'e been trying to sort problem another set of eyes may se something the other centre missed. Quote Link to comment Share on other sites More sharing options...
