markybhoy86 Posted June 3, 2008 Share Posted June 3, 2008 Looking for a good alarm-clifford with turbo timer and start thing-cant remember the term lol i had a quick search but wanted to see what the best,affordable, one was to get from everyone cheers M Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted June 3, 2008 Share Posted June 3, 2008 Looking for a good alarm-clifford with turbo timer and start thing-cant remember the term lol i had a quick search but wanted to see what the best,affordable, one was to get from everyone cheers M Im not sure but i think the Clifford avantguard system has one. It has a load of extra options which can be installed on this alarm... Im going with this one shortly... Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted June 3, 2008 Author Share Posted June 3, 2008 do u have a link? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 3, 2008 Share Posted June 3, 2008 I've got the Clifford 600 I think. It does everything although I wouldn't bother with a turbo timer if it was me. I never use mine at all, just cruise slowly for the last part of the journey. It's better for the car than leaving it sitting at idle. Also stops grannies telling you "you've left your car on" Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted June 4, 2008 Author Share Posted June 4, 2008 wheres the best place to get one?off the clifford site? cheers M Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 4, 2008 Share Posted June 4, 2008 wheres the best place to get one?off the clifford site? cheers M Personally I'd get it fitted at a Thatcham approved installers such as sextons. www.sextons.co.uk Quote Link to comment Share on other sites More sharing options...
ped87 Posted June 4, 2008 Share Posted June 4, 2008 from memory you can add this stuff to any clifford alarm i know the 600 650 you can some come with it already all depends where you go some companys wont do a turbo timer with a cert Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 4, 2008 Share Posted June 4, 2008 i had a turbo timer fitted on my old clifford. waste of money, just sit in the car and let cool down. as said many times, its ilegal to leave the engine running and lock/leave the car Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted June 4, 2008 Share Posted June 4, 2008 Its an addon for most of the clifford range (i had it added to my concept 650), but they are completely pointless LOL Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 4, 2008 Share Posted June 4, 2008 The less you hack the stock wiring loom about the less trouble you'll have. In my experience the simplest alarms with the least (enabled) features give the least trouble. Some cars have under dash looms that look like someone's been weaving spaghetti there. Quote Link to comment Share on other sites More sharing options...
Scott Posted June 4, 2008 Share Posted June 4, 2008 I got the 650 concept installed. It has built in turbo timer. Cost around £400, i think, all in which included wiring in my remote start (i already had an intellistart module). To get the remote start you will need to buy the module which i think is around £150 so you would be looking at around £500-£600 all in. Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted June 4, 2008 Author Share Posted June 4, 2008 cheers il have a look on the site, to be honest i want the turbo timer, i dont have the patience to sit in the motor for 5 mins lol i do it just now but id rather the money and save myself the hassle Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted June 4, 2008 Share Posted June 4, 2008 I may be wrong, but I'm sure I read somewhere that the intellistart / turbo timer option invalidates the thatcham cat 1 classification. just a point worth noting if it's true. Mike Quote Link to comment Share on other sites More sharing options...
damientt Posted June 4, 2008 Share Posted June 4, 2008 (edited) I've got a turbo timer function on my Clifford Concept 550. It works off a relay and means I can leave the engine running for a fixed period of time (1 minute setting) but still set the alarm. I also have a separate Greddy 'intelligent' turbo timer that works out the idle cut off period depending on how hard the car's been driven ...... but it won't keep running once the alarm's been activated. Edited June 4, 2008 by damientt (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted June 4, 2008 Share Posted June 4, 2008 I may be wrong, but I'm sure I read somewhere that the intellistart / turbo timer option invalidates the thatcham cat 1 classification. just a point worth noting if it's true. Mike Intellistart invalidates it but only if the installer is a real pig about it IYSWIM. As its not part of the system as standard what they don't know won't hurt them. Turbo timer is built into the 650 btw. Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted June 4, 2008 Share Posted June 4, 2008 do u have a link? No sorry dont have a link Markybhoy86 but i do have a number if you want to ring Clifford; 0800 4586008... And its called a Clifford Avantguard 5.5 system... Hope this helps... Quote Link to comment Share on other sites More sharing options...
Scott Posted June 4, 2008 Share Posted June 4, 2008 No sorry dont have a link Markybhoy86 but i do have a number if you want to ring Clifford; 0800 4586008... And its called a Clifford Avantguard 5.5 system... Hope this helps... Just remember the avantguard isn't cat1 as far as i know (because of the intellistart as standard) Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted June 4, 2008 Share Posted June 4, 2008 Just remember the avantguard isn't cat1 as far as i know (because of the intellistart as standard) Isnt it?! Are you sure?? What alarms are cat1 then Scotster?? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 4, 2008 Share Posted June 4, 2008 I don't have an extensive list but as far as the cliffords go all of the modern ones as long as blackjax isn't activated and they don't have intellistart. If you go onto the clifford website it will tell you which ones are cat1 Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted June 4, 2008 Share Posted June 4, 2008 I don't have an extensive list but as far as the cliffords go all of the modern ones as long as blackjax isn't activated and they don't have intellistart. If you go onto the clifford website it will tell you which ones are cat1 Nice one will do, cheers for that mate... Quote Link to comment Share on other sites More sharing options...
Scott Posted June 4, 2008 Share Posted June 4, 2008 Nice one will do, cheers for that mate... The wierd one i found was blackjax. The reason they can't be cat1 when active is because in order to qualify for certification the car cannot cut out due to the alarm under any circumstances.... even when being stolen lol. Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted June 4, 2008 Share Posted June 4, 2008 The wierd one i found was blackjax. The reason they can't be cat1 when active is because in order to qualify for certification the car cannot cut out due to the alarm under any circumstances.... even when being stolen lol. Ahh i see... Quote Link to comment Share on other sites More sharing options...
