heckler Posted June 3, 2008 Share Posted June 3, 2008 ok, Having finally bought UK rear brakes to go with the front, ideally, do you need to change the master cylinder, as I am assuming the UK/Jspec are a different size/bore? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 3, 2008 Share Posted June 3, 2008 They'll work fine with your stock brake master cylinder, no need to change it. Quote Link to comment Share on other sites More sharing options...
heckler Posted June 3, 2008 Author Share Posted June 3, 2008 They'll work fine with your stock brake master cylinder, no need to change it. Really?! Oh, ok Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 3, 2008 Share Posted June 3, 2008 Is the UK spec Brake master cylinder bigger tho? Is there anything to prevent people using different Brake Master Cyclinders from bigger brake cars when upgrading to a BBK? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 3, 2008 Share Posted June 3, 2008 No, you can use different bore size cylinders, so long as you can mount it. If you are doing something radical it may be better or easier to make a dual master cylinder set up, lose the ABS and be able to adjust bias from within the car, and choose master cylinders to suit front and rear caliper piston areas independently. I did this on my Skyline, if you want a nosey the pics are at ftp://ftp.chriswilson.tv/Skyline_Stuff Quote Link to comment Share on other sites More sharing options...
