Fuel leak from AN fittings to fpr
csa
I've just installed another fpr, but the AN fittings to the NOS system leaking a bit (maybe a drop every minutte). I can see that there has previously been used a white material as som sort of non seizing gasket.
what should I use here?
AN fittings should need no sealing - there is a cone on the male fitting that fits into a cone shaped bit in the female. Unless the female bit is a port (i.e. no cone bit) in which case you need a dowty seal which is a metal washer with a rubber center basically. PTFE won't do the job, that's for NPT tapered threads.
as above, also make sure the seats are not damaged a slight nic or dent will cause a leak
when mounting the an fittings to the fpr it's just a straight end, not at cone, that's beeing screwed into the fpr. I just spoke to my local tuner and he uses teflon tape to make a tight seal.
