csa Posted June 3, 2008 Share Posted June 3, 2008 I've just installed another fpr, but the AN fittings to the NOS system leaking a bit (maybe a drop every minutte). I can see that there has previously been used a white material as som sort of non seizing gasket. what should I use here? Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 3, 2008 Share Posted June 3, 2008 Teflon? I'd be cautious with different materials it can contaminate the fuel Someone will be along shortly to advise accordingly Quote Link to comment Share on other sites More sharing options...
SimonB Posted June 3, 2008 Share Posted June 3, 2008 AN fittings should need no sealing - there is a cone on the male fitting that fits into a cone shaped bit in the female. Unless the female bit is a port (i.e. no cone bit) in which case you need a dowty seal which is a metal washer with a rubber center basically. PTFE won't do the job, that's for NPT tapered threads. Quote Link to comment Share on other sites More sharing options...
paul mac Posted June 3, 2008 Share Posted June 3, 2008 AN fittings should need no sealing - there is a cone on the male fitting that fits into a cone shaped bit in the female. Unless the female bit is a port (i.e. no cone bit) in which case you need a dowty seal which is a metal washer with a rubber center basically. PTFE won't do the job, that's for NPT tapered threads. as above, also make sure the seats are not damaged a slight nic or dent will cause a leak Quote Link to comment Share on other sites More sharing options...
csa Posted June 3, 2008 Author Share Posted June 3, 2008 when mounting the an fittings to the fpr it's just a straight end, not at cone, that's beeing screwed into the fpr. I just spoke to my local tuner and he uses teflon tape to make a tight seal. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 3, 2008 Share Posted June 3, 2008 If its screwing into the Aeromotive FPR base that side of the fittings usually come with a rubber o-ring. JIC flare shouldnt use PTFE as already mentioned as you run a risk of binding up on the PTFE and not on the 37 degree part of the flange. Quote Link to comment Share on other sites More sharing options...
csa Posted June 3, 2008 Author Share Posted June 3, 2008 there's no O rings included. what is JIC and PTFE short for? Quote Link to comment Share on other sites More sharing options...
supradibbs Posted June 3, 2008 Share Posted June 3, 2008 As Rob says on the aeromotive its a non tapered fitting therefore should be used with a rubber o ring contact joe at phr he supplied me with me complete with the o ring Quote Link to comment Share on other sites More sharing options...
csa Posted June 3, 2008 Author Share Posted June 3, 2008 btw it's not an aeromotive fpr but a Sard Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 3, 2008 Share Posted June 3, 2008 Post up a photo of the regulator and the fitting (separated) and i should be able to tell you what the correct way of sealing them is. Quote Link to comment Share on other sites More sharing options...
csa Posted June 3, 2008 Author Share Posted June 3, 2008 will take photos later today Quote Link to comment Share on other sites More sharing options...
