Flipfinger Posted August 9, 2002 Share Posted August 9, 2002 Squeaky when I turn either way, even when the engine is fully warmed up. My first thought is power steering fluid - and the cap rather handily says "Fill to correct level" - which is what? Quote Link to comment Share on other sites More sharing options...
eyefi Posted August 9, 2002 Share Posted August 9, 2002 under that handily marked cap is a dipstick that has the hot and cold ranges marked on it. the hot method is more accurate. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 9, 2002 Author Share Posted August 9, 2002 Right, cheers - looks like the level is just under the HOT sign - doh! Quote Link to comment Share on other sites More sharing options...
Rob Posted August 9, 2002 Share Posted August 9, 2002 Thats what mine did, shortly before the pulley sheared off. Have you had your drive belt or cambelt changed by Toyota previously, as their blowtorch method caused all my problems. Otherwise you might just need a new belt at £60 odd. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 9, 2002 Author Share Posted August 9, 2002 Nope, Toyota haven't touched it.....got the cambelt changed when I bought it (about a year ago) though, by an independant garage. Quote Link to comment Share on other sites More sharing options...
Rob Posted August 9, 2002 Share Posted August 9, 2002 I suggest you phone tem up and ask them the precise method they used to remove the crankshaft drive pulley. Mine sheared off as I was braking into a roundabout, which was interesting to say the least. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 9, 2002 Author Share Posted August 9, 2002 Well, I'm going to investigate the power steering fluid first. Quote Link to comment Share on other sites More sharing options...
Terminator Posted August 9, 2002 Share Posted August 9, 2002 If you spray some water onto the belt and it goes away then its the belt. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 10, 2002 Author Share Posted August 10, 2002 I think it IS the belt.......as it squaks when the ignition is turned off too..... Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 10, 2002 Share Posted August 10, 2002 ??? ??? The belt isn't doing anything when the ignition is off! Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 10, 2002 Author Share Posted August 10, 2002 No, as you turn the engine off, it squeaks briefly - I assumed it was the belt stopping Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 11, 2002 Share Posted August 11, 2002 Ah. Does it do it more when you go to full lock? That's when the load on the PAS pump will be higest. Or does it also happen when you turn A/C on? Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 16, 2002 Author Share Posted August 16, 2002 Turns out it's an engine pulley - £320, if you please. It'd be easier to stomach if I wasn't going to sell it next month. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted August 16, 2002 Share Posted August 16, 2002 Originally posted by Flipfinger Turns out it's an engine pulley - £320, if you please. It'd be easier to stomach if I wasn't going to sell it next month. I've heard this from somebody else recently. They thought they had a PAS fault and they ended up with the crank pulley falling off on them. I wonder if it happens if somebody has previously bodged a cambelt change. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 16, 2002 Author Share Posted August 16, 2002 Yeah - it happened to Rob! I just thank Christ that I stopped driving it when it started to make an irregular noise. Quote Link to comment Share on other sites More sharing options...
Flipfinger Posted August 16, 2002 Author Share Posted August 16, 2002 Just found out my warranty doesn't run out till the 7th of next month! Fingers crossed that it's covered. Quote Link to comment Share on other sites More sharing options...
Rob Posted August 16, 2002 Share Posted August 16, 2002 Told ya! If you buy next month's Smug Magazine, I'm on the front cover. Quote Link to comment Share on other sites More sharing options...
