Measuring bore size - spigot rings
Lukeyboy2k
How do I measure the bore size of aftermarket wheels? I need to know this so I can purchase some spigot rings. There seem to be a few possibilities I can see from the reverse of my wheel.
<!--url{0}-->[/img]</p><p> </p><p> <img src=[/img]
<!--url{2}-->[/img]</p><p> </p><p> I think A and B [i]might[/i] be the same dimensions. I gather the internal diameter requirement for a spigot ring for the Supra is 60.1mm. Correct??</p><p> </p><p> Alternatively, if anyone actually has the same wheel, what size do you use (Work Meister S2R 18"x9, x10)?</p><p> </p><p> Any help most appreciated.</p>
Is it just me or does the bore (hole) in the wheel look tapered?
They're tapered on every set of wheels I've seen.
The measurement needs to be taken very accurately so you'll need a gauge to ensure you get the right size (down to 0.1mm I think)
