Clifford Alarm stopped chirping/ not working correctly? Read on! (How-to guide)
Pabs
Result! Don't supose you know how to disable the auto locking on a Clifford? I just know that sooner or later I'm going to lock myself out :(
I was playing with the Cliffnet the other day and thought it would be a good idea to enable it. How wrong was I? Three days later and I'm swapping the cars over in the drive and mange to lock myself out of the car with the engine running. Luckily I was at my house so no drama, just get the spare.
I don't fully understand some of the settings in cliffnet (such as the auto-lock at RPM - where do you set the RPM it locks at??)
I don't have the lock upon auto-arming feature on, but I do have the auto-arming on. That said, if I switch auto-arming off, it makes no difference at all - the LED does still start flashing after about 30 seconds regardless - I think this is the immobiliser etc kicking in though.
Yes - the majority of the settings can be changed from the main keyfob. However, you'll need to know which alarm you have to then download the manual - then you can figure out which button sequence it is to change the setting you want.
Cliffnet makes it much easier (assuming you have the cliffnet port somewhere in the car?)
About 2000 - that's generally when I'm on the move.
sorry - bad wording on my part - HOW do you set the RPM to lock at?
Currently mine locks instantly, which is annoying as I reverse out of the garage, and then the missus needs to get in, but the door is locked... (perhaps that's a bonus lol)
ahha... usb -> RS232 converter?
I know you can get the G5 cliffnet wizzard which uses a usb cable, but would it work with g4 system?
Si - I have the G5 Cliffnet wizard on my Concept 600 (G4) and it works fine.... at least it seems to.
  • 1 year later...
sorry to restart an old thread but I have a clifford alarm that was already on my car when I bought it and it chirped fine when I locked and unlocked it but a couple of months ago it stopped (double)chirping when I lock it but still (single)chirps when I unlock it, this doesnt sound like the battery has gone to me. Any help? Thanks
No no no thanks for resurecting it!
My alarm has started donig exactly this!
Now i know what this issue is :p
It stopped chirping when i lock and unlock and also when the alarm goes off and was thinking it was just a random electrical thing. now i know how to fix it.
The other day i was getting a wheel ballenced. got back in the car to go home and get in the car and turn the key and the car goes mental. alarm going off. i was like wtf how is it doing that. it hasnt been working for a week or 2. anyway after a while it stopped going off and all seemed fine.
Ill try gettnig a battery.
  • 1 year later...
Guest daver1015
Hello,
I know this is an old thread but maybe someone can help.
I have the 50.7 and there is a communication issue somewhere. When I hit the arm, dis arm try to remote start they all work, the problem is that the keyfod indicates otherwise. It makes a weird sounds and does not show that the function was successful even though it was. I bought a new keyfob and programmed it correcty. I am thinking the problem is in the alarm unit it self. Does anybody have any ideas?
Thanks...
