csa Posted May 31, 2008 Share Posted May 31, 2008 When running an fairsized oilcooler, what should the oiltemp be when cruising with 4000rpms? on mine it's climbing over 100C...something wrong? Quote Link to comment Share on other sites More sharing options...
supra matt Posted May 31, 2008 Share Posted May 31, 2008 (edited) When running an fairsized oilcooler, what should the oiltemp be when cruising with 4000rpms? on mine it's climbing over 100C...something wrong? Yes that is a bit warm mate should be between 80 to 90 deg's at that speed , Where is the temp sensor located? Also them temps are with the standard cooler so yours should be about 70 to 80 max Edited May 31, 2008 by supra matt (see edit history) Quote Link to comment Share on other sites More sharing options...
csa Posted May 31, 2008 Author Share Posted May 31, 2008 thought so. could it be the thermostat in the sandwichplate thats not opening for the cooling unit? Quote Link to comment Share on other sites More sharing options...
supra matt Posted May 31, 2008 Share Posted May 31, 2008 Might be but if it still has the standard cooler on it ? then this should keep the temps under control . Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 31, 2008 Share Posted May 31, 2008 where is the standard oil cooler, i never knew they had one or is that a uk car thing? Your car has a mocal oil cooler, i cant remember what the oil temps was but that does sound high, do i remember you having trouble with a split oil cooler hose? Quote Link to comment Share on other sites More sharing options...
supra matt Posted May 31, 2008 Share Posted May 31, 2008 where is the standard oil cooler, i never knew they had one or is that a uk car thing? Your car has a mocal oil cooler, i cant remember what the oil temps was but that does sound high, do i remember you having trouble with a split oil cooler hose? They all have them Jamie its a wet one that sits behind the oil filter runs off the coolant circuit. Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 31, 2008 Share Posted May 31, 2008 They all have them Jamie its a wet one that sits behind the oil filter runs off the coolant circuit. Ahh ok, yea id say thats still in place unless tf removed it without my knowledge. Quote Link to comment Share on other sites More sharing options...
csa Posted May 31, 2008 Author Share Posted May 31, 2008 where is the standard oil cooler, i never knew they had one or is that a uk car thing? Your car has a mocal oil cooler, i cant remember what the oil temps was but that does sound high, do i remember you having trouble with a split oil cooler hose? i did. but just had a hose replaced Quote Link to comment Share on other sites More sharing options...
csa Posted June 2, 2008 Author Share Posted June 2, 2008 any suggestions guys? just tried to top off the water as well, but it's still aproching 100 when cruising the highway. I can feel that the oil is going through the cooler as it gets hot Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 2, 2008 Share Posted June 2, 2008 I would try another gauge. Quote Link to comment Share on other sites More sharing options...
csa Posted June 2, 2008 Author Share Posted June 2, 2008 I'm guite sure that it's reading correct (ish) as the oil is smoking hot after a drive (when opening the oilfiller cap) Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted June 2, 2008 Share Posted June 2, 2008 (edited) whats the water reading? my water is norm around 80-90 deg with the oil being around 80deg thats with a 16 row oil cooler has this all ways given that reading on since the repair on the oil line? Edited June 2, 2008 by johnd-mkiv (see edit history) Quote Link to comment Share on other sites More sharing options...
supra matt Posted June 2, 2008 Share Posted June 2, 2008 Also what are the egt's reading ? What oil are you running it on to mate? Quote Link to comment Share on other sites More sharing options...
csa Posted June 2, 2008 Author Share Posted June 2, 2008 haven't got an egt at the moment, so don't know. oil is Silicolene Pro S 10w50 Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted June 2, 2008 Share Posted June 2, 2008 This might make you feel a bit better. http://www.mkivsupra.net/vbb/showthread.php?t=91460&highlight=total I see just under 120C on a track day. That's with the standard cooling oil set-up. Quote Link to comment Share on other sites More sharing options...
Pig Posted June 2, 2008 Share Posted June 2, 2008 my rs4 stays at about 100 and thats a new car. The supra is the same but peaked 137 at marhan Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted June 2, 2008 Share Posted June 2, 2008 do you have a water guage? this will give you a rough idea if the oil temp guage is running out? Quote Link to comment Share on other sites More sharing options...
Mike B Posted June 2, 2008 Share Posted June 2, 2008 my rs4 stays at about 100 and thats a new car. The supra is the same but peaked 137 at marhan Ow!!! When I see 110 a yellow light pups up and my turbo melted yet the oil never saw above 115.. Normally it sits at 85-90 peaks at 95 on the road. I use a small mocal which is poorly ventilated. Michel uses a dirty big one in the drivers side nosecone and he never saw above 85 at Marham... when he had a gearstick I'll be doing a michel install soon. edit; my water never goes above 95 degrees even when my oil is 110. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 2, 2008 Share Posted June 2, 2008 Whats the optimam temperature an oil should be running at? Quote Link to comment Share on other sites More sharing options...
Mike B Posted June 2, 2008 Share Posted June 2, 2008 I aksked the guys at opie and they said nothing over 110, nothing under 70., although under 100 is the key.. it starts to unwind the molecules over 100 degrees more rapidly apparently... Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted June 2, 2008 Share Posted June 2, 2008 Whats the optimam temperature an oil should be running at? Above 80C to help get rid of any condensation build up. A good synthetic oil will deal with temps up to 150C, although a more normal operating band is between 90C - 120C. Quote Link to comment Share on other sites More sharing options...
