firepool Posted May 31, 2008 Share Posted May 31, 2008 Hi all To inspect a possible brake sticking on, I've removed my n/s front caliper and it looks like only 2 of the 4 pots are actually moving (the two nearest to where the fluid hose connects. Are the other 2 supposed to move as well? Also, as I was pumping the brake pedal, 1 of the pistons came out too far and a bit of fluid came out. The piston went back in ok but will this cause me any problems? Thanks Quote Link to comment Share on other sites More sharing options...
dannypunto Posted May 31, 2008 Share Posted May 31, 2008 if u clamp the 2 pistons that move freely in position , then get a pump, and connect it on the brake hose and pump the other 2 pistons out, pump really hard and they should pop out completly, give them a clean and grease them and pop them bk in Quote Link to comment Share on other sites More sharing options...
simbasupra Posted May 31, 2008 Share Posted May 31, 2008 Hi all To inspect a possible brake sticking on, I've removed my n/s front caliper and it looks like only 2 of the 4 pots are actually moving (the two nearest to where the fluid hose connects. Are the other 2 supposed to move as well? Also, as I was pumping the brake pedal, 1 of the pistons came out too far and a bit of fluid came out. The piston went back in ok but will this cause me any problems? Thanks They should all move, so i suspect 2 are sticking slightly, what i would do is buy an overhall kit and replace the seals and clean up the pistons. By the way the overhall kit is fairly cheap direct from Toyota. Edit... You also get the correct grease when you buy the overhall kit. Quote Link to comment Share on other sites More sharing options...
merckx Posted May 31, 2008 Share Posted May 31, 2008 (edited) They should all move, so i suspect 2 are sticking slightly, what i would do is buy an overhall kit and replace the seals and clean up the pistons. By the way the overhall kit is fairly cheap direct from Toyota. Edit... You also get the correct grease when you buy the overhall kit. This would be the best way to go about it if you want it to remain trouble free. Edited May 31, 2008 by merckx (see edit history) Quote Link to comment Share on other sites More sharing options...
firepool Posted May 31, 2008 Author Share Posted May 31, 2008 Thanks for your help guys, looks like I'll be investing in an overhaul kit then Quote Link to comment Share on other sites More sharing options...
firepool Posted May 31, 2008 Author Share Posted May 31, 2008 Just done a search and found the part no. Front - 04479-14140. I'll still have the problem of extending the 2 sticky pistons though won't I? Quote Link to comment Share on other sites More sharing options...
turnerjr Posted May 31, 2008 Share Posted May 31, 2008 (edited) just finished reconditioning my uk brakes today, it is really easy. Parts cost £35 from toyota which will do both the fronts. If you can get a piston removal tool its even easier. look at this link http://www.mkivsupra.net/vbb/showpost.php?p=785858&postcount=10 Edited May 31, 2008 by turnerjr (see edit history) Quote Link to comment Share on other sites More sharing options...
