glenn Posted May 31, 2008 Share Posted May 31, 2008 anybody fitted 60mm boost gauge in air vent above the ingnition switch, if so any do's& don'ts ,thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted May 31, 2008 Share Posted May 31, 2008 I had a 60mm water temp sensor in there. Just be careful when placing the dash back on. Quote Link to comment Share on other sites More sharing options...
steb9780 Posted May 31, 2008 Share Posted May 31, 2008 And make sure you connect the fag lighter back up the right way, there's always some dunce that does the polarity back to front Quote Link to comment Share on other sites More sharing options...
glenn Posted May 31, 2008 Author Share Posted May 31, 2008 And make sure you connect the fag lighter back up the right way, there's always some dunce that does the polarity back to front i want to put gauge other side ,above ingnition switch.as it looks a smaller panel & switches to remove,as it was a nightmare putting panel back after fitting stereo Quote Link to comment Share on other sites More sharing options...
steb9780 Posted May 31, 2008 Share Posted May 31, 2008 Like I already said I am a dunce, I can't even read your post properly.............. Quote Link to comment Share on other sites More sharing options...
Nicolai Posted May 31, 2008 Share Posted May 31, 2008 i want to put gauge other side ,above ingnition switch.as it looks a smaller panel & switches to remove,as it was a nightmare putting panel back after fitting stereo Lol also starting to fit my sterio today mate, and my boost gauge! Did you receive my item? I'm thinking of placing my 60mm gauge in the place where the old clock should be. (Try to make it fit ) Quote Link to comment Share on other sites More sharing options...
Supradan Posted May 31, 2008 Share Posted May 31, 2008 Hi glenn my tt had a 60mm boost gauge in the airvent next tothe clock. Quote Link to comment Share on other sites More sharing options...
glenn Posted May 31, 2008 Author Share Posted May 31, 2008 hi dan.was going to put there ,but it was so much hasel when fitting stereo,trying to get dash back,with extra boxes &wires for sat/nav,don't really want to go there again, Quote Link to comment Share on other sites More sharing options...
