fuel pump problem in a facelift
Spoony
hi
a friend tried to install an eu spec fuel pump in his facelift jspec.
the eu pump starts for 2 seconds then stops.
when he takes direct + and - from the batterie it works, when he puts back the jspec pump with the oem plugs it also works.
do we have to make some changes with the pump harness??
what is the problem??
thanks
Can you not just wire it so it's on a switched live feed?
IE, not use the original connector?
Not a great idea, as the pump will then continue to run when the engine isn't. Like when you're upside down in a ditch and it's pumping fuel out into your hot engine bay...
