pete.w Posted May 27, 2008 Share Posted May 27, 2008 hi pips, just a quick question ive fitted a tempreture gauge for the water system and wondered what is the normal tempriture reading supose to be on me tt uk .its reading about 85c is this about right, thanks in advance Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted May 27, 2008 Share Posted May 27, 2008 Where is the sensor positioned and did you check the gauge for accuracy before you fitted it? Quote Link to comment Share on other sites More sharing options...
pete.w Posted May 27, 2008 Author Share Posted May 27, 2008 the gauge is just a cheapo one so dout if it accurate, the sesor ive fitted between the top rad hose, it reads about 85c on tickover and when running it goes to 90c .just need to know what the normal temp readings are. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted May 27, 2008 Share Posted May 27, 2008 the gauge is just a cheapo one so dout if it accurate, the sesor ive fitted between the top rad hose, it reads about 85c on tickover and when running it goes to 90c .just need to know what the normal temp readings are. thats normal operating temps mate;) Quote Link to comment Share on other sites More sharing options...
Homer Posted May 27, 2008 Share Posted May 27, 2008 Yep, 85 is the temp they always run at (single, BPU or stock, with the sensor in the top rad pipe). 90 is a getting a little higher than normal, but thats nothing to worry about at all. Quote Link to comment Share on other sites More sharing options...
pete.w Posted May 27, 2008 Author Share Posted May 27, 2008 thanks pips Quote Link to comment Share on other sites More sharing options...
