UK Brake Install - Dust shields?
Mike_Mac
I'm in the middle of refurbing a full set of UK brakes prior to swapping them with my existing J-specs.
I know you can either cut or remove the existing J-Spec front dust shields, but I was wondering if it's just as simple to fit UK dust shields instead, as I'd prefer to use the right kit from the outset rather than angle grinding the old.
Is this a case of unbolting old and attaching new, or is it more involved than that.
Also does anyone know of any UK ones that are available? :)
Does anyone have the part numbers for the rear shields please?
And the fronts - I don't fancy trying to explain to Mr T what a dust shield is - I'd probably end up with anything from a hub to a brake disc! :D
Thanks for the all the answers guys - I take it you'd need a press to get the hubs off? If so then grinding the UK shields to get them on seems the better option!
I'd just trim the the J-Spec ones unless you thrive on hassle and expense :)
You do remember my Supra don't you? :D
Wouldn't the option given above of sliding the UK shields on by trimmng a section out work without having to remove the hubs?
If it did then does the UK shield make a notable difference over the modified J-Spec, because if it's of little impact then I'll save the hassle and trim the J-Spec ones.
(Enough hassle and expense inbound with replacing the suspension arms! :blink:)
  • 3 weeks later...
As far as I can remember, you dont need them. The UK rear brakes will fit over the Jspec rear shields. I only ever remember cutting off the fronts when fitting the UK brakes to my GZ.
I already have the UK brakes. I want to replace my rusty shields when I replace the disks ;)
  • 6 months later...
A single hex ring or combination open ended / ring spanner will undo them easily. I have never had trouble undoing them with a normal bi-hex ring or combination though, either. If you're paranoid, apply heat before undoing them. If you knacker them grind them off, but they'll undo with a decent spanner.
Thanks Chris. I looked for a hex ring but never had one. I'll invest in one tomorrow. If I grind them off or snap one, how do I manage to re-thread the hole as the hub will be slightly in the way.
I am assuming you are just binning the water shield and won't be fitting a bigger UK type. Don't grind them off (obviously) if you intend to fit a new one ;) You'll get better brake cooling without a shield *UNLESS* you make up a proper ducted one and feed it with pressurised cold air
Actually I'm just swapping my rusty UK ones for new UK ones :innocent: I'll get a ring spanner and report back :)
