supraspeed Posted May 26, 2008 Share Posted May 26, 2008 how much is it for house of kolor candy pain averagly to coat an entire supe? anyone done this? Quote Link to comment Share on other sites More sharing options...
ivan Posted May 26, 2008 Share Posted May 26, 2008 Ask Supra-Woman. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 26, 2008 Share Posted May 26, 2008 Why HOK? There are others out there, the Lecher ink dye for instance is around £60/l from memory roughly Quote Link to comment Share on other sites More sharing options...
Konrad Posted May 26, 2008 Share Posted May 26, 2008 HoK is not just one paint, it is combination of many elements, each of them have to be bought seperate. Then you have to find bodyshop which done or was trained to do HoK paints as it is not that simple as normal painting. Also you should know, that if anyone will scratch your car, there is no easy way to cover it (actually there is no chance you will match paint) so you have to respray at least all element. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 26, 2008 Share Posted May 26, 2008 HoK is not just one paint, it is combination of many elements, each of them have to be bought seperate. Then you have to find bodyshop which done or was trained to do HoK paints as it is not that simple as normal painting. Also you should know, that if anyone will scratch your car, there is no easy way to cover it (actually there is no chance you will match paint) so you have to respray at least all element. Very good point.. Candy paint is a transparent and not a solid colour, so it changes the colour of the basecoat. Candy has to go on VERY evenly and it isn't the easiest thing to do. Matching afterwards can be done but will usually NEVER be right unless you are damn lucky. HOK is just a paint brand with lots of effects in there range. Quote Link to comment Share on other sites More sharing options...
