spiderpigcity Posted May 25, 2008 Share Posted May 25, 2008 if i want to run a afr gauge and an egt gauge can i tap into the AEM ecu or do i have to drill a hole in the downpipe for the egt. what do i connect the afr gauge to ? Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 25, 2008 Share Posted May 25, 2008 They both have sensors that need to go in the exhaust, the egt sensor can also go in the turbo or manifold runners, i had mine mounted in the turbo. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted May 25, 2008 Author Share Posted May 25, 2008 They both have sensors that need to go in the exhaust, the egt sensor can also go in the turbo or manifold runners, i had mine mounted in the turbo. so just drill and tap the turbo exhuast housing with two holes then? Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 25, 2008 Share Posted May 25, 2008 The afr sensor needs to go in the downpipe, read the instructions;) the egt sensor can go in the turbo, but you have to remove it if you want to do that or just put it in the downpipe but it will read a bit low. Quote Link to comment Share on other sites More sharing options...
and1c Posted May 26, 2008 Share Posted May 26, 2008 so just drill and tap the turbo exhuast housing with two holes then? Just buy a wideband kit like this Wideband kit and you get the gauge and sensor and all the install bits. Like JamieP says, its important the sensor is installed in the right location to obtain accurate and meaningful readings. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted May 26, 2008 Author Share Posted May 26, 2008 Just buy a wideband kit like this Wideband kit and you get the gauge and sensor and all the install bits. Like JamieP says, its important the sensor is installed in the right location to obtain accurate and meaningful readings. i have just ordered AEM ems and 3.5bar sensor, iat, and wideband. i cant read the instructions as i havnt received them yet. i am asking the question as i thought the downpipe would already have 2 sensors in it for the aem and i wondered if you can tap into these with the gauges. Quote Link to comment Share on other sites More sharing options...
