Nic Posted May 25, 2008 Share Posted May 25, 2008 Ah happy memories 3PCOcyt7BPI Quote Link to comment Share on other sites More sharing options...
uk-rich Posted May 25, 2008 Share Posted May 25, 2008 what does kai mean ? Quote Link to comment Share on other sites More sharing options...
Nic Posted May 25, 2008 Author Share Posted May 25, 2008 what does kai mean ? No idea, apparently it was named after 2 businessmen; Sir Ho Kai and Mr. Au Tak Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 25, 2008 Share Posted May 25, 2008 what does kai mean ? Kai means "holly cr@p, we're going to hit that building". Great vid Nic. Quote Link to comment Share on other sites More sharing options...
Ian R Posted May 25, 2008 Share Posted May 25, 2008 Not much fun Quote Link to comment Share on other sites More sharing options...
ivan Posted May 25, 2008 Share Posted May 25, 2008 When my missus went to HK they flew into there. She all but sh!t herself. Quote Link to comment Share on other sites More sharing options...
loks Posted May 26, 2008 Share Posted May 26, 2008 Indeed fond memories....with approximately 20 landings at the old Kai Tak under my belt. Twas certainly spectacular. Used to be a rooftop restaurant there called the Yellow Banana which was always fun to take guests Quote Link to comment Share on other sites More sharing options...
supra steveo Posted May 26, 2008 Share Posted May 26, 2008 looks like even the pilots in HK like to do it side ways too Quote Link to comment Share on other sites More sharing options...
Trig Posted May 26, 2008 Share Posted May 26, 2008 am i right in thinking this airport is now closed??? great vid Quote Link to comment Share on other sites More sharing options...
tbourner Posted May 26, 2008 Share Posted May 26, 2008 In 1998 according to the vid. Can any pilots on here confirm that the 'drifting' on landing is actually to slow the plane down and lose some hight ASAP, rather than because of crosswinds as everyone seems to wrongly believe? Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted May 26, 2008 Share Posted May 26, 2008 thats amazing, the stress on the undercariage must be huge when they land on the angle like that. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 26, 2008 Share Posted May 26, 2008 so thats why pilots are paid so much!! Quote Link to comment Share on other sites More sharing options...
tommygun Posted May 26, 2008 Share Posted May 26, 2008 Quote Link to comment Share on other sites More sharing options...
robin Posted May 26, 2008 Share Posted May 26, 2008 I thought the sidways landing was called crabbing and was done because of high winds. At least this is what a pilot told me. Quote Link to comment Share on other sites More sharing options...
robin Posted May 26, 2008 Share Posted May 26, 2008 http://www.fromthecockpit.com/Pilot_Crabbing.html Quote Link to comment Share on other sites More sharing options...
Why T Posted May 26, 2008 Share Posted May 26, 2008 i dont understand why they had to land like that? Quote Link to comment Share on other sites More sharing options...
China Man Posted May 26, 2008 Share Posted May 26, 2008 I remember flying back to HK each year at the old airport and I can see through the window into the flats below and see whats on TV Just enough time to make out which channel they are watching. Quote Link to comment Share on other sites More sharing options...
tbourner Posted May 26, 2008 Share Posted May 26, 2008 I thought the sidways landing was called crabbing and was done because of high winds. At least this is what a pilot told me. Ooh, research suggests it's actually both!! There is sideslipping, forward slipping and crabbing. The definition of a Forward slip; the terminology Forward Slip refers to the technique of increasing drag to allow an increased descent rate. In the absence of wind, the forward slip is a bit diffucult to coordinate and ensure that drift is zeroed out with rudder being applied in one direction and aileron being used to counter the induced roll. The definition of a Side Slip; the terminology Side Slip refers to the technique of crosswind landing whereby the upwind wing is lowered and the rudder is applied to counteract the tendancy to turn the aircraft. If coordinated properly, the aircraft will have no tendency to drift to either side of the runway and will track the centerline. The definition of a Crab; the terminology Crab refers to the technique of zeroing drift in a crosswind by turning into the wind sufficiently with the wings level (same as correcting for drift when cross country flying). This technique of crosswind landing can be considered preferable to passengers who may not like to view the runway at an angle when side slipping. However, as pointed out previously, the crab requires precise timing and if performed improperly can impose large loads to aircraft landing gear not specifically strengthend. So crabbing is to reduce the effects of crosswind, you have to pull out of the crab just before landing to prevent damage to the undercarriage. Slipping is also turning sideways, but in low wind conditions, and this IS to lose altitude quickly. Side Slipping is facing straight down the runway and tipping one wing down to effectively turn into the sidewind, so again negating it's effect. I think slipping is more for small aircraft and crabbing is for larger passenger jets - passengers don't tend to like seeing the runway approaching whilst half rolled over!! Quote Link to comment Share on other sites More sharing options...
