ehaust leak!! Help
danny_silva
hi guys!! i just had my 2nd cat removed!! i then went for a drive and realized that my boost gauge was reading 10.5 psi.... before it was reading 11psi!!
will a exhaust leak effect my boost pressure causing it to read less??
it most have to be very small, after letting the car getting cold again i started it up and have a check on all the weldings!! I didnt feel any air movement coming out!!
anyone that than help me on this??
Cheers
Danny
it does a bubling noise at idle and when i drive is sounds good!!very quiet!! i thing prob there is a leak, very small one!!! ill get under the car tomorow with a bit of paper a check again all my weldings!! prob there is one so small that it leaks a small amout of air under hard aceleration causing to lose only 0.5 psi...... not sure!! any help is very apprecieted!!
An exhaust leak that for back will have little to no effect on the boost pressure.
The difference you have seen could just be down to air temps and humidity. In the summer mine used to change by as much as 4psi between mid day and the evening.
