Socket to hold damper shaft?
merckx
I've just removed the spring/damper assembly on the van so I can replace the top bearing.
The threaded damper shaft obviously has a nut which I want to remove but I need a special socket to hold the shaft while I loosen the nut.
There's just a couple of flats on the shaft, the only trouble is that the nut and shaft are recessed down below the top mount.
Is there a special socket that I can buy to use with a wrench that has the profile shown below.
Thanks
8mm across the flats
Was going to suggest Moley's.. thats what you'de normally use, some has a Hex or Torx and some have what you got
I didn't use them at the normal location for holding it though, there was already rust at the top of the damper shaft which is hidden by the plastic stop so the grip marks left by the mole grips didn't matter anyway.
