Gutting the cat
ben_stevo
I have a 1994 NA supra and I want to decat it, on my old car (Glanza) I just took the cat off and gutted it (smashed all the internals out) and it worked excellent and didnt cost me a penny! Can you do this with the Supra and will it still pass an mot? If so which cat should I gut as I believe there is 2? Thanks
I did my 1st cat like this. Took a total of 20 hours to gut the 1st cat. 2nd cat I chucked loads of nitro methane in an set it a light. This stuff burns hot and melted most of it but i think the casing is donald ducked now :(
It took about 2 mins at the most with my old Glanza, hacked at it with a hammer and chisel, How comes it takes so long on the supra? Does it make the car any louder as at the minute mines way too quiet for my liking. Think im going to have a go at it tomorrow, how hard is it to remove the 1st cat?
1st cat is the part where it goes from 2 pipes to 1 pipe from the head. It takes long to gut because the metal is so far down you can't get pliers in too well. It does increase the noise a little.
Yea, metal like a honey cone. I used a hammer and chisel to start with and hammered most of it out with a long screw driver. I then used long pliers to grabs the bits out. Its not an easy job with the na 1st cat.
this is a ridiculous method im sorry, just buy a decat pipe, why risk all that debris flying about inside and potentially red hot metal hitting car bumpers behind you as they fly out or blocking up your 2nd cat, causing a massive blockage and melting things, there cheap enough to buy now and keep the cat for your MOT
Also, the cat material is very very poisonous, do NOT breath it in! Best way if you insist on gutting it, soak it in oil first to stop dust and fragments flying in the air and getting breathed in. Also be careful what you do with the remains as it could be very harmful to animals, wildlife etc. if left around.
Much better to just buy a decat pipe as they're really not expensive!
i agree, buy a pipe for 90 quid.
I didnt cecide to do it, just been down to my local stainless exhaust place and decided to do it properly by getting it stainless straight through
nice one dude....best to be safe and keep things on the car done properly, its an expensive car to put right;) enjoy the extra growl now :cool:
