JamieP Posted May 23, 2008 Share Posted May 23, 2008 Good luck with it and be sure to let us know how it goes, we also like pics;) Quote Link to comment Share on other sites More sharing options...
gaz1 Posted May 23, 2008 Share Posted May 23, 2008 where are kent performance based matey Quote Link to comment Share on other sites More sharing options...
heckler Posted May 23, 2008 Share Posted May 23, 2008 where are kent performance based matey erm... Kent?? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted May 23, 2008 Share Posted May 23, 2008 erm... Kent?? Ha ha ha. Im assuming so, the guy is from Kent aswell.......... Quote Link to comment Share on other sites More sharing options...
Homer Posted May 23, 2008 Share Posted May 23, 2008 Just make sure they didn't use any other XS power compenents... such as oil feed and return, fuel lines, FPR, gaskets, pressure lines, etc. They are utter garbage and won't last longer than a few months (nearly lost my car and myself after a fuel line of theirs perished) Quote Link to comment Share on other sites More sharing options...
gaz1 Posted May 23, 2008 Share Posted May 23, 2008 erm... Kent?? Ha ha ha. Im assuming so, the guy is from Kent aswell.......... i know that dimwits but kent is a big place:p Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted May 24, 2008 Author Share Posted May 24, 2008 I am responding on Steve's ID as we have not joined yet. My name is Craig and I run Kent Performance. I just wanted to clarify a couple of points regarding Steve's car in order to clear up any confusion. We feel for Steve where the XS power kit is concerned as imo the rest of the kit does look good and reasonable well made for the price, but the Turbo has been a big problem. The Turbo that is going back on is a far from standard GT35. It's a GT35 compressor housing with roller bearings, running a .84 Exhaust housing with the correct manifold flange and V-band, so it will be direct fit. We are running water cooled for extra piece of mind. We decided on a GT35 on advice on what sort of power was required and what the car is used for, i.e a daily driver. So we don't want a huge laggy turbo this time around, and it will be good for 500 BHP. It is a shame as the car made good power at low boost with the XS turbo, but the quality was no good at all. We cannot recommended fitting the kits, as any comebacks like this are a nightmare, especially as XS power do not seem to give a s**t. Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 24, 2008 Share Posted May 24, 2008 (edited) Must be a very special GT35 to have a 4" V band, the XS power kits have been done to death on here and people have had problems with all aspects of the kit, beware and good luck:) Edited May 24, 2008 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
and1c Posted May 24, 2008 Share Posted May 24, 2008 (edited) Looks like I'm being had over again. Will have to wait and see. Will be Kent Performances prob to get it together. Jamie P is right on the money with regards to 'it wont fit like for like'. 4" v band? Edited May 24, 2008 by and1c (see edit history) Quote Link to comment Share on other sites More sharing options...
and1c Posted May 24, 2008 Share Posted May 24, 2008 I am responding on Steve's ID as we have not joined yet. My name is Craig and I run Kent Performance. I just wanted to clarify a couple of points regarding Steve's car in order to clear up any confusion. We feel for Steve where the XS power kit is concerned as imo the rest of the kit does look good and reasonable well made for the price, but the Turbo has been a big problem. The Turbo that is going back on is a far from standard GT35. It's a GT35 compressor housing with roller bearings, running a .84 Exhaust housing with the correct manifold flange and V-band, so it will be direct fit. We are running water cooled for extra piece of mind. We decided on a GT35 on advice on what sort of power was required and what the car is used for, i.e a daily driver. So we don't want a huge laggy turbo this time around, and it will be good for 500 BHP. It is a shame as the car made good power at low boost with the XS turbo, but the quality was no good at all. We cannot recommended fitting the kits, as any comebacks like this are a nightmare, especially as XS power do not seem to give a s**t. Sorry for the long winded post, but if we can help anyone else out please contact us, 01634 360693, and we are based in Gillingham, Kent. If the turbo is a GT35 and it has roller bearings then it is a GT35R...not a GT 35 Quote Link to comment Share on other sites More sharing options...
Guest KentPerformance Posted May 24, 2008 Share Posted May 24, 2008 If the turbo is a GT35 and it has roller bearings then it is a GT35R...not a GT 35 My mistake, I forgot to add the 'R', although essentially they are the same!. We are all to aware of the fitting issues, but the turbo is being built with a 4" V band. We spec our own turbo's all the time. When it's here and on the car i'll get some pics up. Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 24, 2008 Share Posted May 24, 2008 Look forward to the pics, what .ar are you going with? divided or non divided? Quote Link to comment Share on other sites More sharing options...
Guest KentPerformance Posted May 24, 2008 Share Posted May 24, 2008 Look forward to the pics, what .ar are you going with? divided or non divided? It's a .84 exhaust housing, and the only housing that was avaliable was non divided. It's not a problem with the XS power manifold, as there is no division in that. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted May 24, 2008 Share Posted May 24, 2008 You are using the XS manifold?! Have you checked the WG area? Quote Link to comment Share on other sites More sharing options...
Guest KentPerformance Posted May 24, 2008 Share Posted May 24, 2008 Yes, we are using the XS manifold. The wastegate, and all it's piping are all working fine at the moment, and I hope for Steve's sake that they continue to. I can't seem to find any fault with the manifold's construction - it seems to be the best part of the kit! Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 24, 2008 Share Posted May 24, 2008 Yes, we are using the XS manifold. The wastegate, and all it's piping are all working fine at the moment, and I hope for Steve's sake that they continue to. I can't seem to find any fault with the manifold's construction - it seems to be the best part of the kit! The general opinion on the xs manifold is they are badly designed and made, the internal welding where they come together is bad and parts of the weld have been known to come off and go though the turbo killing it (not what you would want with your new GT35r) Also some people have had problems with the car over boosting because the wastegate port hole was not cleaned up and caused a restriction. You may also find the turbo will need spacing up to clear the runners because the flange points in the wrong direction. Quote Link to comment Share on other sites More sharing options...
Guest KentPerformance Posted May 24, 2008 Share Posted May 24, 2008 The general opinion on the xs manifold is they are badly designed and made, the internal welding where they come together is bad and parts of the weld have been known to come off and go though the turbo killing it (not what you would want with your new GT35r) Also some people have had problems with the car over boosting because the wastegate port hole was not cleaned up and caused a restriction. You may also find the turbo will need spacing up to clear the runners because the flange points in the wrong direction. We had heard of the rep of XS power before the kit was fitted, but after looking at this kit,price etc and checking it all during fitting, we were happy to proceed. After fitting the car went on the rollers, and after numerous runs there were no boost spikes or anything else, and it was set at 12 psi. (417bhp at the wheels). As for turbo spacing, it is physically about the same size and orientation, so there is no reason why it will not bolt on with no reasonable problems. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 24, 2008 Share Posted May 24, 2008 I'm pretty sure you can specific the compressor and exhaust vband size (as well as A/R, etc) when ordering from garrett. To be honest Steve, it's a good thing the XS GT45 went, they're a dinosaur of a turbo and not really suitable for a road car. The Garrett GT35r will be completely different animal, it's far more suited to road use. And to Kent Perfomance - make sure the face of the T4 flange on the XS manifold is machined flat, there have been problems with them being warped in the past. Hopefully all that remains of the XS kit is the manfold and the wastegate, if not prepare to be replacing the rest very soon! Quote Link to comment Share on other sites More sharing options...
Guest KentPerformance Posted May 24, 2008 Share Posted May 24, 2008 I'm pretty sure you can specific the compressor and exhaust vband size (as well as A/R, etc) when ordering from garrett. And to Kent Perfomance - make sure the face of the T4 flange on the XS manifold is machined flat, there have been problems with them being warped in the past. Hopefully all that remains of the XS kit is the manfold and the wastegate, if not prepare to be replacing the rest very soon! We are being quite specific with this turbo, so that we know it will be right for the job. The car has been running, with no exhausts leaks or blows - so I guess Steve has a good manifold! LOL, as for the rest of the kit, I hope it remains ok too. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 25, 2008 Share Posted May 25, 2008 Good turbo choice, here are a few pics of my GT35R this has AR .82 and 3" V-band flange. Very fast spooling turbo, positive boost just over 2K rpm, peak boost around 3.5K rpm in higher gears, producing 542hp. http://img142.imageshack.us/img142/8893/cimg0004sj0.jpg http://img297.imageshack.us/img297/3871/cimg0007uv1.jpg http://img132.imageshack.us/img132/9102/cimg0011to0.jpg http://img132.imageshack.us/img132/6208/cimg0013vv0.jpg Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted May 25, 2008 Author Share Posted May 25, 2008 When I got the tubo I did seek some advise and was told by Paul WHIFFIN that the best thing to do would be to throw it in the bin, but hey another expensive lesson learnt. Thanks for all your messages. I shall just assume the feotal position, suck my thumb, cry and work out how the hell I'm going to squeeze the money from my accounts without the wife finding out Quote Link to comment Share on other sites More sharing options...
razza Posted May 25, 2008 Share Posted May 25, 2008 hope you get it sorted properly so you don't have another expensive lesson;) Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted May 25, 2008 Author Share Posted May 25, 2008 Me too. The car is drinking money Quote Link to comment Share on other sites More sharing options...
