Jake Posted February 14, 2005 Share Posted February 14, 2005 Would one of you guys with a pre-facelift TT be kind enough to whip off the footwell fuse cover, have a look at the diagram on the inside of the cover and tell me which fuse is "ECU Ig"? I'm still trying to diagnose the fault with my power steering. I want to make sure it's not an electrical problem before I change the steering rack. From an earlier thread I think I need to check there is voltage across the "Ecu ig" fuse in the drivers side footwell. The problem is that my fuse cover is missing so I can't tell which fuse is the "Ecu ig" one. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
colsoop Posted February 14, 2005 Share Posted February 14, 2005 Here you go http://homepage.ntlworld.com/colin.lewarn/fuse%20panel.jpg Quote Link to comment Share on other sites More sharing options...
