Computer problem please help!
far
Can anyone help me out please - laptop at home is fooked, my BT dial up was upgraded from evening and weekends to anytime free of charge,it wouldnt work and after various bits of things being updated/changed by BT it worked for about 2 days.Then it got screwed, BT reckon its nothing to do with them and after doing numerous tests they have asked me to describe the problem as:
100% failure on ping test (0 returned)
connection ok for 10 seconds then I get page cannot be displayed.
Components currupted in TCP/IP ?
Does anyone know what the hell I need to do to sort this out? Apparantly its nothing to do with their connection.Anyone shed some light on this?
(Windows 2000)
This is the interesting bit - you mean you can actually get websites/ping within that 10 seconds?
What are you pinging? A URL or an IP?
ie - http://www.rocketuk.net - or 217.196.2.3 (They are the same server)
If you can ping the number, but not the name - it's a DNS problem.
What is the error that Ping gives you?
question is what is causing the connection to drop?
fingers point towards the access number...
can you use another payg service provider access number to test out your laptop, that would then eliminate it and point wholly towards BT's service. if indeed it is at fault.
Could be your MTU settings as well....for dial-up your looking at 576.
