Twin to Single Turbo, I need help please ?
Batmax
Hi
1º Question:
I start to put the single turbo and now I need to know if I have to eliminate the parts marked in red and green ?
2º Question:
I have 2 holes in each side of the these wastergate could you make a design where I put the tube(orange line tube and brown line tube) and where he goes to the engine connect ?
Where I connect the boost controoler IN and OUT line tube on these wastergate, thanks.
3º Question:
I put the injection site is right in the grip of round piece of aluminum, or needs to go further into ?
the first things circled in red on the 1st pic need to be removed.Where the pipe with the flange is removed (on the engine block)you will need what they call an "EGR block off plate" .This blanks off the hole left from where the pipe went.
on pic 2 you can remove the cage with the pressure tank as this is no longer needed.
Edited by Rich (see edit history)
