NA and TT shells the same?
PhilMorrison
ACL list the mains as the same part number, and a slightly different partnumber for the con rod bearings.
The sizes, and crank details are listed as identical, so I can't understand why there would be difference.
I'm replacing the crank in my TT engine with an NA GS300 crank, so could do with knowing.
i 'think' it maybe a oil way/hole difference between the NA and TT........in fact reading the manual it shows the flow diagram for the oil as passing through "Piston internal oil galleries" on the TT engine. So i think you need to pick the part number dependant on the piston type.
Bit late now but i should be able to compare TT and NA bearings tomorrow evening to see 100%.......
