Brake fluid, Changing to 5.1
Scott
I'm going to be doing what i can with regards to a service pretty soon and i can't be sure what brake fluid the previous owner has put in.
I've read that brake fluids should not be mixed so how do i make sure all the old stuff is out? Do i just get a few bottles of 5.1 and flush it out a couple of times to get rid of as much as i can?
Don't want to break anything.
I'm going to be taking the calipers off anyway to paint them at the same time as i am fitting my coilovers (oh joy)
I'm gonna be doing this shortly as I need to overhaul the rear calipers. I'm planning on using a big syringe and remove as much as possible from the reservoir so I can fill it with fresh stuff before I start bleeding through. Should help anyway.
Is there not something you have to be careful of with the master cylinder seals when bleeding or have I just made that up? something like flipping a seal, dunno really
I've seen sharks doing that on discovery ;)
Yeah big syringe sounds like the best idea. That way it will be a minimal amount left to get rid of.
LOL,:D with big nasty teeth an all.
Yeah gives you a head start on bleeding the new stuff though.
