Scott Posted May 20, 2008 Share Posted May 20, 2008 I have ordered my coilovers so i am just waiting on them shipping from the US. I quite fancy giving it a go myself so i was trying to make a list of all the tooling i will require so that i am ready as soon as they arrive. I have: A good range of spanners, sockets etc Axle Stands Trolley Jack Scissor Jack Spring Compressors I cant find any ramps that will get near my car so i will just need to get a hold of a block of wood to drive onto so that i can get the scissor/trolley jack under but after that i should be good to go. Anyway, am i missing anything? Should i get a hold of a torque wrench or just do everything up FT? I'm pretty sure thats all the garage did when they fitted my springs the last time. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted May 20, 2008 Share Posted May 20, 2008 yep, thats all you should need. quick tip, you dont need to remove any suspension arms to do it Quote Link to comment Share on other sites More sharing options...
jamesmark Posted May 20, 2008 Share Posted May 20, 2008 Have a look, HTH http://www.mkivsupra.net/vbb/showthread.php?t=52789 Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted May 20, 2008 Share Posted May 20, 2008 thats similar to how I do it, on the rear you will need to remove the caliper to get enough room to swig the shock past it, another tip is to jack up both sides, and undo both shocks, that way your not fighting the anti roll bar all the time, I also used a scissor jack and a block of wood to jack the suspension arms down. Quote Link to comment Share on other sites More sharing options...
Scott Posted May 20, 2008 Author Share Posted May 20, 2008 Have a look, HTH http://www.mkivsupra.net/vbb/showthread.php?t=52789 Thanks James, i spotted that already so i will be using that for the rears. I'm hoping the front is almost as straight forward. Do i just do everything up FT then? Quote Link to comment Share on other sites More sharing options...
Scott Posted May 20, 2008 Author Share Posted May 20, 2008 thats similar to how I do it, on the rear you will need to remove the caliper to get enough room to swig the shock past it, another tip is to jack up both sides, and undo both shocks, that way your not fighting the anti roll bar all the time, I also used a scissor jack and a block of wood to jack the suspension arms down. I've spotted a few things in various searches, one showed pulling the pin from the wishbone to get it out the way. Hopefully i won't face many problems. I should be able to borrow one of my mates as a strong arm lol. Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted May 20, 2008 Share Posted May 20, 2008 I found the fronts easier, yep, FT seems to work Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 20, 2008 Share Posted May 20, 2008 Get a big mate who has some weight, esp for the rear ones . Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted May 20, 2008 Share Posted May 20, 2008 really, its a one person job, just use a scissor jack and a block of wood. Quote Link to comment Share on other sites More sharing options...
bignum Posted May 20, 2008 Share Posted May 20, 2008 I used a 2ft length of 2x2 wood to lever things down using your foot. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted May 20, 2008 Share Posted May 20, 2008 I used a 2ft length of 2x2 wood to lever things down using your foot. No messing about undoing anything apart from the coilovers themselves. Quote Link to comment Share on other sites More sharing options...
heckler Posted May 20, 2008 Share Posted May 20, 2008 i did mine myself - 3.5 hrs from wheels off, to wheels on Quote Link to comment Share on other sites More sharing options...
Scott Posted May 20, 2008 Author Share Posted May 20, 2008 Sounds like fun, i won't book it in for alignment until i have actually fitted them though lol. Quote Link to comment Share on other sites More sharing options...
