Duffman Posted May 19, 2008 Share Posted May 19, 2008 Going to paint my brakes black and have seen sum nice ones that have 'Supra' on the side...whats the best way to clean them and where do I get thsese graphics??? Cheers:search: Link to comment Share on other sites More sharing options...
jacko Posted May 19, 2008 Share Posted May 19, 2008 I could make you some up, let me know Link to comment Share on other sites More sharing options...
Sandy-m2 Posted May 19, 2008 Share Posted May 19, 2008 How much Jacko? Link to comment Share on other sites More sharing options...
merckx Posted May 19, 2008 Share Posted May 19, 2008 Do a search, that's what someone else would have to do to find the link, it's been covered many many times. Link to comment Share on other sites More sharing options...
SatSport Posted May 19, 2008 Share Posted May 19, 2008 look here, couple of posts down http://www.mkivsupra.net/vbb/showthread.php?t=148549&highlight=%60chrome+decals%60&page=2 chrome decals on black........ i still have one set left;) Link to comment Share on other sites More sharing options...
Chris-B Posted May 19, 2008 Share Posted May 19, 2008 http://cgi.ebay.co.uk/TOYOTA-Supra-Brake-Caliper-Decals-Original-Pattern_W0QQitemZ260242064685QQihZ016QQcategoryZ10428QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 proper vinyl jobbies well worth the cash, used these my self and the results were excellent Link to comment Share on other sites More sharing options...
fri3ndly Posted May 19, 2008 Share Posted May 19, 2008 http://cgi.ebay.co.uk/TOYOTA-Supra-Brake-Caliper-Decals-Original-Pattern_W0QQitemZ260242064685QQihZ016QQcategoryZ10428QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 proper vinyl jobbies well worth the cash, used these my self and the results were excellent I bought and fitted these the other day. Perfect! Link to comment Share on other sites More sharing options...
Duffman Posted May 19, 2008 Author Share Posted May 19, 2008 jus bought them there will i get good results if i just mask them off or would i be better taking a bit more time and takeing them off...how long will this take roughly? any of u guys recommend a paint to use thanks again Link to comment Share on other sites More sharing options...
Chris-B Posted May 19, 2008 Share Posted May 19, 2008 id take the caliper off and clean it up with a wire brush to get all the sh*t off then give it a rub over with some wet and dry to get a good surface for the paint. Mine were UK spec calipers and came off very easy, just two bolts at the back of each. Remove the brake pads and the caliper should lift off the disc. I used mole grips on the brake pipe to stop the bake fluid coming out, not to tight though as you might damage the pipe. If you do this remeber to bleed the brakes otherwise you will be in trouble lol, just remove the bleed nut and pump the pedal until the air is out then replace the nut. Link to comment Share on other sites More sharing options...
Duffman Posted May 20, 2008 Author Share Posted May 20, 2008 thats wot im sh***ing it a bit for because i aint really too great at that kind of stuff...dont want the brakes failing at 120(kph) does anyone know where i could get step by step instructions because i want to take them off and get the best results on my supra anyone recommend a paint to use??? im doing them black to go with the black bodywork Link to comment Share on other sites More sharing options...
fri3ndly Posted May 20, 2008 Share Posted May 20, 2008 You could just take the wheels off but leave the calipers on and then paint straight on with a brush. Just give them a really good clean and wire brush. I know a lot of people who have done this. It just means that the inside wont be painted (the bit that noone sees) Link to comment Share on other sites More sharing options...
Chris-B Posted May 21, 2008 Share Posted May 21, 2008 Nothing to worry about just get a friend to help you out by pressing the brake pedal, then just wait untill all the air is out (the fluid will flow freely then make sure your friend holds the brake pedal and replace the nut but dont over tighten. Also just a word of warning, brake fluid is very corresive dont let it touch the paint work etc. Link to comment Share on other sites More sharing options...
