rltc wiring and calibrating
R-TT
Ok iv searched this alot and finaly managed to get it fitted to what i think is right.
i followed this link to fit the 8 wires on the ecu:
http://mkiv.com/techarticles/racelogic_Install/index.html
but i found my abs ecu was not the same as the us one in the above link or the same as the common one i found in most diagrams on here, mine is a facelift manual tt but the abs ecu is the same as this one i think? which is an vvti one? with the 12 an 26 pin, would this be right for my car?
http://www.mkivsupra.net/vbb/showthread.php?t=70518&highlight=fitting+rltc
anyway assuming thats all right i tried to calibrate it but it seems to calibrate untill i turn the car off an then when i restart it its no longer working, as if it loses its settings.
basically how have ppl calibrated theres and is my wiring correct if i have used the above diagrams
Thanks
  • 2 weeks later...
cheers mate, gave them a ring an they want as much to look at it as fit it, plus they dont seem to take appointments by phone which was a little annoying
cheers tho, any on here do it?
