R-TT Posted May 16, 2008 Share Posted May 16, 2008 Ok iv searched this alot and finaly managed to get it fitted to what i think is right. i followed this link to fit the 8 wires on the ecu: http://mkiv.com/techarticles/racelogic_Install/index.html but i found my abs ecu was not the same as the us one in the above link or the same as the common one i found in most diagrams on here, mine is a facelift manual tt but the abs ecu is the same as this one i think? which is an vvti one? with the 12 an 26 pin, would this be right for my car? http://www.mkivsupra.net/vbb/showthread.php?t=70518&highlight=fitting+rltc anyway assuming thats all right i tried to calibrate it but it seems to calibrate untill i turn the car off an then when i restart it its no longer working, as if it loses its settings. basically how have ppl calibrated theres and is my wiring correct if i have used the above diagrams Thanks Quote Link to comment Share on other sites More sharing options...
SimonB Posted May 16, 2008 Share Posted May 16, 2008 Here is a thread with the wiring for a facelift... http://www.mkivsupra.net/vbb/showthread.php?t=33991 Quote Link to comment Share on other sites More sharing options...
R-TT Posted May 20, 2008 Author Share Posted May 20, 2008 ok my wiring is right so how come its not storing the calibration? how have people done theres? Quote Link to comment Share on other sites More sharing options...
R-TT Posted May 30, 2008 Author Share Posted May 30, 2008 ok any1 kno who can look at this for me around the midlands, it seemed to work for a while but has stopped and iv rechecked the wiring and it seems ok. Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 30, 2008 Share Posted May 30, 2008 CenterGravity are installers - http://www.centergravity.co.uk - based near Tamworth if that's any use? Quote Link to comment Share on other sites More sharing options...
R-TT Posted May 30, 2008 Author Share Posted May 30, 2008 cheers mate, gave them a ring an they want as much to look at it as fit it, plus they dont seem to take appointments by phone which was a little annoying cheers tho, any on here do it? Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 30, 2008 Share Posted May 30, 2008 You might want to try another RLTC unit just as a quick test. Wiring issues shouldn't make it lose its configuration, it is stored in non-volatile memory... -Ian Quote Link to comment Share on other sites More sharing options...
