Diff Oil Light...
SBDJ
Morning all...
My diff oil light has come on this morning from cold, I've jacked the car up in attempt to check the diff oil level, but some muppet has destroyed the filler bolt on the diff - it's completely rounded off, and it looks like they've had a go with a chisel too. I've applied some heat and tried to get it off without success :(
Any suggestions?
Regards,
Scott
The sensor is bi metallic switch, it's state is either open or closed. Just disconnect the plug from it, if the light goes out get a new sensor.
Ah fair enough, wasn't sure if it was an analouge one or if it was just a normal therm-switch :) (Learn something every day :))
Disconnected the plug from the sensor, no change, light still on. Shorted the pins on the plug, still no change, light still on...
I don't suppose you know where these wires run back to, so I can test them with a meter?
Regards,
Scott
  • 5 years later...
