123tom123tom Posted May 15, 2008 Share Posted May 15, 2008 I have just tried doing the above Mod, it did not seem to work at all, I was getting about 0.3 bar boost and a funny noise when i let of the gas like bwooop noise(just say it how it is spelt and that is the noise) what i didnt do is block the vsv off when i took the pipes off would this cause issue... It just didnt go anywhere what would cause this to happen.... Quote Link to comment Share on other sites More sharing options...
edge Posted May 15, 2008 Share Posted May 15, 2008 There is no need to block the vsv off from stock as it wont do nothing. Have you got an ebc fitted? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 15, 2008 Author Share Posted May 15, 2008 no it is just running 1.2 bar with a restrictor ring in.... Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 15, 2008 Author Share Posted May 15, 2008 anybody got any suggestions Quote Link to comment Share on other sites More sharing options...
Pig Posted May 15, 2008 Share Posted May 15, 2008 Yep, you put the pipes on wrong. they need to cross over. Did the same thing myslef. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 15, 2008 Author Share Posted May 15, 2008 what do you mean can you try to explain, i followed the online guide...... Quote Link to comment Share on other sites More sharing options...
Pig Posted May 15, 2008 Share Posted May 15, 2008 Which guide? Just swap the 2 pipes over on the end that you have changed and try it againn. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 15, 2008 Author Share Posted May 15, 2008 right this is what i have done, i put the yellow arrow pipe onto the the t-piece where the pink arrow is and took pipe that was there totally off...... then at the other end where the green arrow is, i took that pipe off and replaed it with a new longer hose that now goes from the green arrow straight to the lower actuator nipple not the lower vsv... i took that pipe off that goes from lower vsv to actuator... does this make sense Quote Link to comment Share on other sites More sharing options...
Pig Posted May 15, 2008 Share Posted May 15, 2008 IIRC and it was about 2 years ago. where the pink and yellow arrows are i put the pipes on the wrong way round. which guide are you using. I think i used hecklers. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 15, 2008 Author Share Posted May 15, 2008 wheres heckler guide, plus you cant get the pipes you said the wrong way round it is just taking the pipe that comes from the actuator at the top and sticking it on the t-piece where the pink arrow is , then you just discard the other.... Quote Link to comment Share on other sites More sharing options...
edge Posted May 15, 2008 Share Posted May 15, 2008 Where the green arrow is - Should have pipe coming from end of black metal pipes next to bov and it should go to the actuator directly below it. Bit of a fiddle but ok to do. Other bit is ok - from actuator number 6 in pic straight onto T peice Edit - did you actually take the car out for a drive as it wont work until it hits full boost a couple of times. Quote Link to comment Share on other sites More sharing options...
heckler Posted May 15, 2008 Share Posted May 15, 2008 have you tried following this guide? Quote Link to comment Share on other sites More sharing options...
Pig Posted May 16, 2008 Share Posted May 16, 2008 have you tried following this guide? Thats the one. Easy as pie following that Quote Link to comment Share on other sites More sharing options...
MRX Posted May 16, 2008 Share Posted May 16, 2008 Ok, the mrs has gone out, im at a loose end so gonna go try this Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 16, 2008 Author Share Posted May 16, 2008 this mod just aint working on my car is there any other factors that would stop it from working.... the car works fine in normal mode if that helps, runs a full 1.2 bar when needed etc, no vacuum leaks, intercooler needs replacing i think, its a bit brittle. any ideas, i have hooked this mod up correctly, for that i am certain...... Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 16, 2008 Author Share Posted May 16, 2008 anymore theories behind this Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 17, 2008 Share Posted May 17, 2008 Have you taken it above 4k a few times ? Doesn't the pressure tank need to build pressure first ? I seemed to remember having to do that before it worked. incidentally i used the non return valve method on mkiv.com: http://www.mkiv.com/techarticles/ttc/ttc.htm i personally didn't like it and went back to how it was designed originally and more importantly setup for. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 17, 2008 Share Posted May 17, 2008 Yes if pressure tank if fooked it wont work. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 17, 2008 Author Share Posted May 17, 2008 pressure tank???????? what is this and how come it doesnt effect the normal seq system Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 20, 2008 Author Share Posted May 20, 2008 bump.... still no joy on this mod, and dont know why it aint working.... duff intercooler maybe????? Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 20, 2008 Share Posted May 20, 2008 Have you gone passed 4k a few times ? When you have done it do you notice the exhaust note change ? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 20, 2008 Author Share Posted May 20, 2008 Have you gone passed 4k a few times ? When you have done it do you notice the exhaust note change ? not really noticed the note change that much.... i went on my local bybass and took it above 4k about 6-7 times but it felt like there was no boost at all even though the gauge stated 0.4 - 0.5, when letting off the gas a funny noise would happen like a bwop, that just could be the hks bov not been sucked hard enough and making that noise. ?????????? what next Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted May 21, 2008 Author Share Posted May 21, 2008 i have got it workin,,,, and am not that impressed, after driving it with the seq system, and now the ttc it just feel wrong like it is broken or something:). So back to seq mode, a hope going single wouldnt be as disappointing. Quote Link to comment Share on other sites More sharing options...
edge Posted May 21, 2008 Share Posted May 21, 2008 i have got it workin,,,, and am not that impressed, after driving it with the seq system, and now the ttc it just feel wrong like it is broken or something:). So back to seq mode, a hope going single wouldnt be as disappointing. So what was wrong ? how did you get it working? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 21, 2008 Share Posted May 21, 2008 i have got it workin,,,, and am not that impressed, after driving it with the seq system, and now the ttc it just feel wrong like it is broken or something:). So back to seq mode, a hope going single wouldnt be as disappointing. Are you sure? that the response most people have when its not working right, if its working right you would notice believe me;) Quote Link to comment Share on other sites More sharing options...
