Suspension arm ball joint - have I broken it?
Homer
As with everything on the rear suspension, the lower balljoint was being a "bit stuborn". It was too wide for my splitter to get on it so tried the heating it and then used a hammer.. no joy, so being a patient bloke, out came Mr Sledge Hammer...
Anyway, the balljoint came out after a few hits, but now I cannot get the nut off because the balljoint is rotating with the nut. Have I broken it?
No its ok, just get some long nose mole grips in there to grip the ball joint to stop it rotating, or push and hold it back in the socket, this might grip it enough so you can unscrew it.
However if you missed with the hammer and damaged the threads you will need a thread file to restore them otherwise you will never unscrew it.
Good luck anyway mate:)
