What EGTs are people getting with Hybrids?
Kn1ght
I've noticed a few threads about EGTs, but they have all seem to have been about Std or BPU.
How do Hybrids alter these temps?
my temps are quite a bit higher than the other's mentioned.
Idling: 450 - 500c
Cruising: 650 - 700c
Going up a hill boosting at about 0.0bar: 850 - 900c
on the flat go peddle full depressed about 1.2: 850 – 900c
is this normal hybrids?
Ross
could the grill infront of the IC have anything to do with it?
It would be better without and with the intercooler properly ducted, it looks from the pic that there is a large area of the FMIC that won't be getting any direct airflow. Your FMIC is probably less efficient than a properly ducted side mounted intercooler would be.
Your sensor is before the turbo, 900C is around the max you would want to see, above this and you are starting to get intro dangerous territory.
Disagree nic, i would say 900 post turbo is getting beyond safe. So 800 before turbo.
I used to max 950 on UK turbo's. I later had an issue that resulted a dead engine. I dont know if it was related to the heat though. (i believe it was the turbo failure.)
His sensor is before the turbo, so 900C is a safe limit. The temp after the turbo is usually around 200C less, so safe limit after turbo around 700C.
950C pre turbo is getting dangerously high.
