Anyone recommend a decent CCTV setup?
Jake
Right then, I want a half decent a CCTV setup to protect my driveway, garage and cars.
Only need a single camera.
Will be externally fixed to the house.
Must have reasonable quality colour picture.
Must be able to record to PC
Anything else I need to consider?
What am I going to need?
Anyone recommend anything or place/website to buy from?
Thanks guys
Maplins seemed to have some good bits...
Get a few night vision cameras and a decent standalone PVR which accepts multiple inputs, they aren't as expensive as I thought myself.
Standalone PVR? Is that really necessary?
I'd go with an IP camera and just record onto a PC - just make sure it's got decent resolution at night when most of the bad things happen.
Can you recommend anything? From eBay would be ideal (for ease of purchasing)
I don't want anything with battery powered cameras though.
Would you be wanting wireless or cable?
Most are intended for indoor use too so it might cost a bit more for outdoors unless you can build it a little perspex house to live in :)
I can do cabled if necessary. Obviously wireless would be easier to install and preferred unless sacrificing image quality/functionality much.
Outdoor use is a must.
I'd probably opt for wired to be honest, the wireless ones can drop out now and again.
Something like:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220232630559
I think CCD is better than CMOS but someone clever might have to confirm that. 720x576 at 30fps is pretty good, works down to almost complete darkness (0.1 Lux). My only concerns would be that it's unbranded, the software might be complete pants and it's a seller in Hong Kong so you could get stung for customs.
Given how many things like this are available from over there it would be really good if someone we trust like Nic could handle the sales, probably for less than we'd pay on eBay too.
It would be good if we could see one up and running first too and check it out at night as well as in the daytime to see how wide the field of view is etc.
Excuse my ignorance, but that's just a camera, isn't it? Surely I can't just connect that up to a PC and have it record, can I? Seems too easy.
It has the rest of the fun built in, IP cameras are quite clever :)
The software on the PC does most of the hard work, the camera has it's own OS / webserver so you can browse to it though.
From the looks of that one you just hook up the network lead, power and a mic if you want sound and that should be it, you'll connect to a default address over the network to configure it all in the same way as you would when adding a wireless router, tell it about your network, configure zones for motion detection etc and away you go...
I might have to get myself one of those for when I move. Sounds like fun. :)
I haven't had a look at it yet, but do you know if its MacOSX compatible?
EDIT: Balls. No. :rolleyes:
And Safari no doubt.
They look good, bit pricy for the quad + HDD + camera but I might have to invest later in the year.
