Is this normal wideband behaviour @ idle
bodilx6
I wouldnt be too worried, what spec is your car? is it BPU? or running a single with aftermarket ECU?
I think it would be possible to get it running a little better with a mapping session depending on your spec.....
other people maybe able to offer a better opinion
Its BPU, stock fuelling except for pump and full decat 3". I'm guessing a calibration of the wideband might help maybe a bit, but it seems to be normal.
Thx mates
What ECU do you have, stock with piggy back, standalone??
11's would be alot safer as 12's at WOT is a little on the lean side.
100% stock. Only performance changes done to the car is full 3" decat and exhaust along with a walbro. I'll check again, might be a bit less than 12.5 then. Wouldn't a normal BPU run a bit rich normally?
Mine runs in the 10's with both tubbies online
