Animal Posted May 13, 2008 Share Posted May 13, 2008 My air con has not worked for the last few months and I've just found how to run the diagnostic test. Anyway, the flashing led's alternated between Fresh Air & Defrost, which according to the list is the Pressure Switch Circuit and the Solar Sensor Circuit. What does this actually mean? I presume the pressure switch means I need to get it re-gassed, but what's the other one? Cheers Link to comment Share on other sites More sharing options...
Nic Posted May 13, 2008 Share Posted May 13, 2008 The Solar Sensor is the red dome thing on top of the dash, it is basically a light sensor. The climate control uses the reading from this and other sensors to automatically adjust the temp. Link to comment Share on other sites More sharing options...
tango Posted May 13, 2008 Share Posted May 13, 2008 Is there anyway you can make the aircon stay on rather then switch on and off itself? cheers Link to comment Share on other sites More sharing options...
Animal Posted May 13, 2008 Author Share Posted May 13, 2008 Yeah, I know what the solar sensor is, but does the error code mean that it's knackered? If so, what's involved in repairing it. I want to get the car booked in somewhere to get re-gassed, etc but would like to know what needs looking at besides a re-gas. Link to comment Share on other sites More sharing options...
SimonB Posted May 13, 2008 Share Posted May 13, 2008 Yeah, I know what the solar sensor is, but does the error code mean that it's knackered? If so, what's involved in repairing it. No, it just means it was bright when you did the test. Or dark, can't remember which is which now. Link to comment Share on other sites More sharing options...
Animal Posted May 13, 2008 Author Share Posted May 13, 2008 Ah right. It were sunny when I tested it this morning. Next question would be - I've found a mobile specialist that will do the following: - De-gas the present refrigerant - Check all component functions and check pipes for corrosion - Deep vacuum and remove moisture content - Replace pollen filter - Full anti-bacterial & Ozone treatment - Re-gas the system with the correct amount of refrigerant - Digitally leak test - Test the system is fully functional but they are charging £110 + vat is this extortionate or is it likely to be a better service than the £45.00 offer at Kwik-Fit? I'd rather pay more to get it thoroughly checked as it hasn't been looked at for at least 3 years (I know, I know) Link to comment Share on other sites More sharing options...
razza Posted May 13, 2008 Share Posted May 13, 2008 These things should be done by Kwik Fit etc. for the £45 I believe - De-gas the present refrigerant - Deep vacuum and remove moisture content (not sure) - Re-gas the system with the correct amount of refrigerant - Digitally leak test - Test the system is fully functional so seems a bit steep to me Link to comment Share on other sites More sharing options...
paul mac Posted May 13, 2008 Share Posted May 13, 2008 Ah right. It were sunny when I tested it this morning. Next question would be - I've found a mobile specialist that will do the following: - De-gas the present refrigerant - Check all component functions and check pipes for corrosion - Deep vacuum and remove moisture content - Replace pollen filter - Full anti-bacterial & Ozone treatment - Re-gas the system with the correct amount of refrigerant - Digitally leak test - Test the system is fully functional but they are charging £110 + vat is this extortionate or is it likely to be a better service than the £45.00 offer at Kwik-Fit? I'd rather pay more to get it thoroughly checked as it hasn't been looked at for at least 3 years (I know, I know) just had the old kwic-fit treatment mate and i am sure i read on the sign if they dont fill it with anything they dont charge Link to comment Share on other sites More sharing options...
razza Posted May 13, 2008 Share Posted May 13, 2008 just had the old kwic-fit treatment mate and i am sure i read on the sign if they dont fill it with anything they dont charge Humpries won't charge you if your air temp doesn't go down 10% Link to comment Share on other sites More sharing options...
Animal Posted May 14, 2008 Author Share Posted May 14, 2008 Bad news. I've just been told my condensor is goosed. I'm now waiting for Mr. T to ring me back with a price to base my search on. Link to comment Share on other sites More sharing options...
Nic Posted May 14, 2008 Share Posted May 14, 2008 Bad news. I've just been told my condensor is goosed. I'm now waiting for Mr. T to ring me back with a price to base my search on. Price from here would be around £190-£200 posted. Link to comment Share on other sites More sharing options...
Animal Posted May 14, 2008 Author Share Posted May 14, 2008 Price from here would be around £190-£200 posted. SOLD! I've just had a quote from Mr. T of £290, so not as bad as I thought, but your price sounds better. PM is on the way mate. In the meantime, I'll just have to buy a cool-bag and some freezer blocks to stick in the footwell, lol. Link to comment Share on other sites More sharing options...
